Wipers
Old 01-27-2019, 12:00 PM
chevykev's Avatar
Default Wipers
Hi, New hummer owner in the UK . Just bought a 2003 H2 & the wipers do not work, ( and we certainly need them here ! )wash works intermittently. Any ideas, have checked fuse. Thanks
Old 01-27-2019, 01:15 PM
oceanbrave's Avatar
Well all the ususal checks spring to mind, check the fuse, check power to the wipermotor connectors.etc. (see pdf)
The wiper itself houses the control module which is prone to failure due to water/moisture ingress, if you're electronically able it is repairable but in any case a new motor is not that expensive.
Someone kindly produced a youtube video
which explains the assembly quite well, although its for a 2005 ModelYear your could well be similar.
Please let us know how you get on, good luck!
File Type: pdf
Old 01-28-2019, 07:07 AM
chevykev's Avatar
Thanks, someone on the uk hummer page suggested that. Will take a look at the weekend
Old 02-02-2019, 02:56 PM
chevykev's Avatar
Default Wipers
Sorted, changed motor. My existing one had been messed about with previously, module not clipped on, wires soldered to motor terminals.....
Old 02-03-2019, 06:18 AM
oceanbrave's Avatar
Good job, did the video help?
Old 02-04-2019, 07:18 AM
chevykev's Avatar
Default Wipers
Yes thanks, hardest part was befitting the panel !
Old 02-05-2019, 03:40 AM
oceanbrave's Avatar
Default Wipe "Clunk" fix
Indeed, a long thin stick helps!
Did you have any play in the driver's side (LHS) pivot bearing?
Mine was really bad, easily 3mm to 4mm. The audible the "clunk" when the wiper changed direction was very annoyingly loud.
I fixed it by cutting a 1/2" tap washer and sliding it in the gap, it also stopped the wiper-blade lifting away from the windscreen. Simple and effective fix.
Old 02-05-2019, 07:12 AM
chevykev's Avatar
Default Wipers
No all good.
hummer_on_fumes
10-27-2019 07:21 AM
TheDoc
04-10-2019 05:40 AM
metzlyov
03-11-2018 08:09 AM
mik100
01-24-2017 03:31 AM
2004H2
02-10-2012 08:29 AM
Quick Reply: Wipers
