Weird sound not sure if that’s the steering wheel bump?
Old Mar 7, 2025 | 11:00 AM
  #31
Where there is a will, there is a way. Nice job and good to hear.
Old Mar 7, 2025 | 07:35 PM
  #32
NFS's Avatar
NFS
today after a long ride I checked the steering wheel fluid and it was like super low. Is that normal? I checked no leaks, maybe it still burping ?
Old Mar 8, 2025 | 12:43 AM
  #33
NFS's Avatar
NFS
thank you
today after a long ride I checked the steering wheel fluid and it was like super low. Is that normal? I checked no leaks and still no sound. maybe it still burping ?
Old Mar 8, 2025 | 12:07 PM
  #34
Spanovich008's Avatar
As long as the pump is not leaking, or making any abnormal sounds, the fluid is likely low due to the last bit of air getting purged from the system from driving it the past couple days.
Keep topping the fluid off if it continues to drop. Eventually, once all the air is completely purged from the system, the fluid should remain relatively stable.
I wouldn’t consider this anything abnormal at this point.
Old Mar 8, 2025 | 12:43 PM
  #35
NFS's Avatar
NFS
yes I think I have a leak somewhere because today it went super low again and the pump was making a sound cus it was low on fluid I added fluid and the sound went away so I have a leak somewhere maybe? Because there is no way it drank that much from air burping …
Old Mar 8, 2025 | 03:37 PM
  #36
Find/REPAIR/stop the leak before you destroy another pulley bearing.
Old Mar 8, 2025 | 03:51 PM
  #37
NFS's Avatar
NFS
found it it’s the small
o ring gasket for the line that goes into the pinion rack side I see it dripping from there. I tried to put another gasket but I guess mine wasn’t the correct size lol so I am ordering the correct size and gonna replace it
Beto
Jul 28, 2023 06:17 PM
cramirez14
Dec 6, 2019 08:20 AM
2005H2
Feb 7, 2018 08:14 AM
Sugardaddy
27
Nov 13, 2006 12:52 PM
bigwood212
Jun 7, 2006 01:05 AM
