Mystery noise, power steering pump?
Old Dec 1, 2017 | 10:36 PM
2005H2's Avatar
Default Mystery noise, power steering pump?
Hey guys
Rig has held up well so far. But yesterday, I noticed an odd noise.
When driving and turning left, I hear a whiny sound coming from what sounds like near the passengers side tire.
The sound doesn't occur when turning right, only when turning left.
The sound does not occur when the vehicle is stopped and I turn the wheel left or right; it only occurs while in motion.
I checked the power steering fluid and it's full. Could it be the pump itself?
Rig has 130k on her.
Wanted to see what you guys think. Thanks in advance!
Here's a link to the sound :
Old Dec 2, 2017 | 08:27 AM
calif phil's Avatar
It's hard for me to tell on the video. I would go to an alignment shop and ask them to check the front wheel bearings, CV axle and other front end components.
Old Dec 2, 2017 | 09:30 AM
Agreed. From what I could hear that does not sound like a power steering pump. Very well could be though but in general it did not sound like a power steering problem I've ever heard anyways.
Old Dec 4, 2017 | 08:16 PM
Crawdaddyjc's Avatar
Hey 2005h2- i actually heard this (or similar) sound coming from mine. It just started saturday as far as i can tell. Mine also happens when turning left. I drove all through my neighborhood trying to replicate it. At first i thought it was the tires making the sound. I started thinking it was the ps pump. I checked fluid and it is fine. I had my idler and pitman arms replaced last year. I know i heard it and my wife did too. I made her ride around with me to verify i wasnt hearing things. Im wondering if it is a wheel bearing issue. I dont know how to check them other than have the shop look when they rotate my tires.
Between the rattles and the odd noises these old trucks make- that whining sound perked my ears. Good luck and hope we find what it is.
Old Dec 4, 2017 | 08:55 PM
NoSpoon's Avatar
Could it be the CV Joints in one of the half shafts?
Old Dec 11, 2017 | 05:36 PM
Nospoon- that is what i believe the issue is. Makes the most sense.
Anyone know how hard they are to replace myself? Or should i have a shop do the work? 13 years of dirt, rust and grime might be better for someone else to deal with! Lol
Old Dec 11, 2017 | 07:59 PM
NoSpoon's Avatar
They are not hard to do at all. I replaced both of mine recently while doing all of the front end as a precautionary measure.
This video is a good example if you only plan to replace the half shafts.
Good Luck!
Old Dec 11, 2017 | 08:46 PM
Wow. Seems easy. I suspect a lot more curse words and busted knuckles!
This is something i will be investigating.
Old trucks need a lot of attention!
Old Dec 28, 2017 | 08:47 AM
Hey 2005h2- just to provide some feedback on my similar issue... wheel bearings. My driver side was shot and the passenger side wasnt far behind. Having them replaced today. Passenger side tire had about 1” play in the tire and drivers side wheel should have fallen off by now lol. At least this is getting fixed and i shouldnt have to worry about it anymore.
Old Jan 6, 2018 | 05:15 PM
So a week later- no noise. Everything is in tip top shape. Steering and handling seems tighter and more responsive. Nice quiet turns. Now to address the evap error code issue.
