Weird sound not sure if that’s the steering wheel bump?
Old Feb 24, 2025 | 12:29 PM
did you follow the factory procedure for bleeding the air from the system?
The sound you describe sounds exactly like air is still in the PS system.
  1. Check the owner's manual for the correct power steering fluid.
  2. Raise the front wheels off the ground and support the vehicle.
  3. Fill the reservoir to the cold line with the correct power steering fluid.
  4. With the engine off, turn the steering wheel lock to lock several times (5 or 6 times).
  5. Check the reservoir and add fluid as needed.
  6. Start the engine and turn the steering wheel lock to lock several times (5 or 6 times).
  7. Check the reservoir again and add fluid if needed.
  8. Lower the front wheels to the ground.
  9. Check the fluid level, power assist, and operation for leaks and bubbles.
Old Feb 24, 2025 | 01:29 PM
NFS's Avatar
NFS
the only thing that I didn’t do off those steps is doing it with the engine off
Old Feb 24, 2025 | 04:18 PM
NFS's Avatar
NFS
I am gonna try to do what you guys recommended for the bleeding process once that rain storm passes. Also what’s weird today I started the car and I drove it and there was no sound then all the sudden like 5 mins later the whine sound started…. It’s so weird
Old Feb 25, 2025 | 05:35 AM
Air in they PS system causes cavitation: Power steering cavitation typically manifests as a whining, groaning, or squealing noise.
Old Feb 25, 2025 | 06:56 AM
NFS's Avatar
NFS
but why sometimes when I drive no sound and then come all the sudden and soentiems as soon as I start the car then it happen. And it increase with the more speed I go? But if I am on park and turn the steering wheel no sound only when the car is moving
Old Feb 25, 2025 | 09:18 AM
skilescm's Avatar
Might be worth checking the reservoir cap seal.
Old Feb 25, 2025 | 09:39 AM
You can drive with the cap off and it will not spray/spill fluid. The noise is not in the reservoir, it is in the pump to rack cylinder.
Old Feb 25, 2025 | 01:50 PM
NFS's Avatar
NFS
so doc you think it’s getting air somewhere ? I mean I replaced the reservoir gasket too when I installed the new pump
Old Feb 25, 2025 | 02:05 PM
It has air in it from when you replaced it. That is the air that you need to bleed out.
Old Mar 3, 2025 | 12:14 PM
NFS's Avatar
NFS
Default Update
I lifted the front tires off the ground and did the step/ 7 times ! Put it down drive it no sound, today this morning I went to the grocery store. A lot he way there no problem no sound. On the way back all the sudden it start to make whiny sound and it’s loud . Why all the sudden it Came! U mean there is no way there is air I bled that ****er 7 times!! Any ideas?
