Front wheel
Old Jul 26, 2023 | 10:13 AM
Beto's Avatar
Default Front wheel
The front wheel is making a kind of squeaky sound will I drive sounds goes away when I press the breake so I replaced the breaks thinking that was the issue but no sound still there I have checked the wheel bearing for any movement there is no movement at all and when I lift the car and spind the wheel there is no sounds any idea what could be thanks
Old Jul 26, 2023 | 11:01 AM
How about lower ball joint? Could be both upper and lower, but I find the lowers squeak when going over minor bumps in the road.
Wheel bearings usually growl or groan when moving and change with speed.
Old Jul 28, 2023 | 02:59 PM
Happy Hummer's Avatar
Agree with above post.
also check your top shock mount bushing and cup. Both sides. Because they have one on top and sandwiched on underside of rod. We have had them wear and squeak, clunk.
Old Jul 28, 2023 | 06:17 PM
NOT "breake" nor "breaks"!
BRAKE
noun: brake; plural noun: brakes
  1. a device for slowing or stopping a moving vehicle, typically by applying pressure to the wheels.
"The front wheel is making a kind of squeaky sound"
Is it a rotational sound(increase/decrease with speed)?
zefrum
May 3, 2011 03:57 PM
Sugarphreak
May 22, 2010 07:52 PM
Zlee
Oct 6, 2009 12:36 PM
cisco
Jul 7, 2008 09:52 AM
jrbnc
Nov 27, 2007 12:38 PM
