UPDATE: Front-end Rattle...Any Suggestions?
Old Aug 7, 2007 | 03:10 PM
  #141
gp1182's Avatar
Default so bad hummer can't figure it out
My vehicle is brand new; its not even at 5000 miles yet.
Every time i'm driving at slow speed, and after at least 15 minutes of driving, a clamping noise comes up.
It sounds as if a small metal box is inside a slightly bigger one and the smaller box keeps banging against the bigger box.
I can hear something clamping or banging under the vehicle. I also feel the clamp or banging on the gas pedal, when i rest my foot on it, and on the brake pad ,when i'm about to come to a stop.
Hummer service first told me that they could not pin point the problem. Then they said that this is common on all H3Xs. They also admitted to have never test drove the car for more then 3 minutes, which i specifically requested. They want me to wait until something brakes or gets worse.
Has anyone experienced this type of problem or have any idea of what this problem may be?
If so, what was the problem, and how was it fixed?
I'm open to any and all suggestions. PLEASE HELP
Maybe this???
Subject: Clunk Or Knock Noise Heard And Felt Through The Steering Wheel Or Brake And Accelerator Pedals - keywords intermediate rattle shaft #PIT4448 - (06/27/2007)
Models: 2007 Hummer H3
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
A clunk or knock noise is heard and felt through the steering wheel or brake and accelerator pedals, the cause is a slip/stick condition in the lower steering shaft. This is a temperature sensitive issue and usually requires the vehicle to have been driven for a period of time to increase under hood temperatures
Recommendation/Instructions:
Replace the lower steering shaft part no. 25776339. There is a high probability that replacing the shaft will correct the condition as there are only a small percentage of parts that exhibit this condition. This PI will be updated when a new part number becomes available.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
[hr]
Old Aug 7, 2007 | 04:28 PM
  #142
07HummerH3's Avatar
Default RE: so bad hummer can't figure it out
I brought ny H3 into the shop today for the TPS to be fixed/replaced, and mentioned the steering/gas pedal "clunk" to the srvc dept -- they immediately knew what the problem was (intermediate steering column).....they ordered the part and said that it is on 2 week back-order. They even offered to pick my truck up at my house when the repair was going to be done ?!? (I've never been offered that before!)
Old Aug 8, 2007 | 10:31 AM
  #143
greenshirt77's Avatar
GP1182- Yes, you are experiencing the same as everyone else- the steering shaft issue.
Most07 H3s were purchased in late '06 and early '07 when the weather was cooler. Thus, some had the issue but didn't realize it because it's not obvious in lower temps.
Some have just purchased recently and are noticing the prob immediately.Mileage is not a factor.
Here's what I know as of yesterday from my dealer. (Hall in Va Beach) I've already covered some ofthis in earlier posts, butI'll recapto make it easier.
The prob is amanufacturing defect in thesteering shaft assembly. Whether this is a fluke issue on a specific batch, or an actual design defect is unknown.
Early speculationindicated that it'smost likely a defect on a specific batch, although that seems unlikely to me. I say this given that dealers were orig instructed to replace the part previously mentioned in this thread, and in most cases it has not only not solved the problem, many reported that the problem was WORSE.(As a result, Hall has completely ceased doing any more "fixes" with the aforementined part.) I'm no rocket scientist, but that suggests to me that there is a design defect.
If it is an issue with a specific batch of shafts, I would hope that GM will be able to pinpoint the VIN range and notify everyone. This is never full proof though, as GMhasissued bulletins/recalls in the past targeting a specific VIN range, only to find out down the road that the range was much broader than originally thought.
All indications are, that as annoying andunstable asthe clunking sound may be, it is not causing any damage to the vehicle or serious concern related to the safe operation of the vehicle.
That said, I can't imagine it's a good thing for the steering shaft to be clunking around for extended periods of time.
The most annoyingaspect of this is that no one seems to know EXACTLY where GM standson this at the moment. Are they designing a proper replacement?Are they simply attempting to devise a more apt "fix"? Word from the servicemanager at Hall is that they are designing a replacement, but absolutely no word on when it will be avail.
For now, we have no choice but to hang in there and wait... and wait... and wait.
This is only my opinion, but I would advise against having the current "fix" performed. Don't do it. It will be a complete waste of time. Some dealers have ceased performing this "fix" for a reason. It doesn't work. All it amounts to is time wasted for nothing. You have to leave your H3, have someone shuttle you around (or rent a car) while the service mechanics go tearing into your H3 steering column (scary enough right there!) and perform work that will not improve the issue, and perhaps will even make it worse. Then you get to go pick it up, hopeful that the problem is gone. And as you drive off down the road with you're fingers crossed, all of a sudden:
Your H3- "clunk clunk"
You-"F*ck!"
Might as well just sit it out, annoying as it is, until a proper fix is available.
Until then- Happy clunking everyone!
Old Aug 8, 2007 | 03:44 PM
  #144
mfish's Avatar
I dont think it was a bad batch, my 06 is at the dealer right now, they just called me to tell me the noise I am hearing is the steering shaft. My H3 was made 10/05.
Old Aug 8, 2007 | 04:15 PM
  #145
Nick119's Avatar
Ugh, today its about 100+ degrees out and I began to hear serious clunks and felt the gas pedal vibrating. So I guess I'm in the mix with you guys. Should I even bother to call the dealer or wait?
Old Aug 8, 2007 | 04:21 PM
  #146
mfish's Avatar
Call them and get on the wait list for the part.
Old Aug 8, 2007 | 04:43 PM
  #147
Yes, what mfish said. Notify your dealer and get on a list for the permanent fix, but don't bother taking it in now.
See the last paragraph of my above post.
Old Aug 8, 2007 | 06:17 PM
  #148
FREDDY0514's Avatar
WELL IT'S STARTING TO GET WORSE ,SO GM BETTER START GETTING THIER **** TOGETHER BECAUSE WIFE AN ME STARTING TO GET ANNOYED AN ALL U GUYS & LADYS TO ARE STARTING TO GET ANNOYED TO[>:]WHY GM LET SOMETHING LIKE THIS GO THAT LONG DON'T UNDERSTAND.
Old Aug 8, 2007 | 07:19 PM
  #149
ikao's Avatar
Default RE: Front-end Rattle...Any Suggestions?
ORIGINAL: HummerGuy
Well, the part number for the NEW/UPDATED part or whatever they want to call it is 25776339
I don't know if this is the same as the existing one, but keep in mind, the dealers were all told to use the existing one until the new one is made. As you said H3PR, it probably is the same part number.
Anyway, the new re-designed part is already on back-order even though it's available now. This is from my friend who works in the Service Department at a dealer as well.
I hope we all get this resolved soon. Honestly, everybody's story seems to add up to a defective batch, and them finding it and taking the old ones away from their inventory and replacing them with the new ones.
it looks like the same part number from PIT4448. is this the newly redesigned piece or the patch until the redesigned piece comes out?
Old Aug 8, 2007 | 07:37 PM
  #150
[/quote]
[/quote]
I'm trying to make this clear- THERE IS NO RE-DESIGNED PART YET!
This above mentioned part is the piece of sh*t temporary fix that is worthless.
Get in touch with your dealer service and tell them you want to be on a list to be notified when the NEW replacement (or other perm fix) is available.
EDIT-After re-reading, I realize this post sounds a bit harsher than it was meant. I'm just trying to clear up for everyone in an attempt to save time and headache. I was one of the first to discuss this issue withmy dealer's service dept. I actually pointed them to this thread a while back. Since then, they have been very pro-active in regards to communicating with GM to stay on top of where things are currently with the situation.
