Self-Serve Car Wash & No-Start
Old May 8, 2021 | 12:43 PM
  #31
Dylan Rogers's Avatar
I also cleaned off/out all the COPs as well as the spark plugs. Two plugs took some penetrating oil and a breaker bar to get loose. I sanded down the surfaces on the ground electrodes of all the plugs. I put a bead of dielectric grease around the sealing surface of the COP where it meets the valve cover and also put an insulating bead on the insulator of the plugs. The #1 cylinder plug had some small cracks on the insulator, but I put it back in anyway. I'll replace the plugs and O2 sensors at the same time.
Old May 8, 2021 | 01:21 PM
  #32
Pending codes are caused by intermittent faults or faults that the PCM needs to see happen in two consecutive warm-up cycles to set the code.
Old May 8, 2021 | 10:53 PM
  #33
Your explanation makes sense. Now the codes are popping up fast and regularly. P0136 and P0137 codes.
Old May 10, 2021 | 08:50 PM
  #34
I re-installed the factory intake baffle and intake tubing to see if my DIY CAI was causing the P0136/P0137 codes. With the factory stuff on, the P0136 took a long while to come on but it did end up coming on. I plan to drive it again tonight and tomorrow morning to see if the P0137 comes back before re-installing my CAI tubing.
bluebow
Feb 22, 2021 10:39 AM
dwaller67
Aug 3, 2019 10:22 PM
yellowhummerh3
May 25, 2018 05:48 AM
HummerGerhardt
Sep 1, 2013 10:49 AM
user 956363738
Sep 20, 2012 12:12 AM
