Help with reattaching the rear fender on a H3
Old Apr 26, 2021 | 02:27 PM
Flynndoman's Avatar
Default Help with reattaching the rear fender on a H3
Hello All- I have a 2009 Hummer H3 that I had a deer run into the drivers side rear fender and break off several of the white plastic mounting clips that attach the fender to the rear passenger door. I went on Amazon and got the correct GM white mounting clips and removed the fender panel, cleaned everything up, and replaced the clips, but for some reason, I cannot get the clips to fully insert into the holes on the vehicle body and "snap into place". Do I need to bend the clip mounting strip slightly "proud- sticking out" to get the clips to engage properly, and securely hold the fender in place? Or is there a special "trick" I need to know to get it to attach in place? I checked my new clips and they are an exact match to the original ones on the Hummer. Thanks for your help in advance.
Old Apr 29, 2021 | 04:41 PM
wpage's Avatar
Threads are useless with out pics.
They should just press on.
Old Apr 29, 2021 | 06:21 PM
Old Apr 30, 2021 | 12:34 PM
Welcome to HF. MOVED your thread as ALL H3 questions go in the .................................................. ..................... that's right............................................. ....H3 Section.
The fenders just pop on. They do not use the "smart clips" that attach themselves while you watch, you have to put some serious effort into it and a quick firm push, almost like pounding on the flare at each clip location with the heal of your hand.
Old May 11, 2021 | 08:20 AM
UcraDen's Avatar
maybe you forgetting to put the rubber filler that goes between the plasic panel and the main body? (thin one, to avoid the friction)
H3steve
Mar 24, 2020 09:28 PM
hunter8793
Dec 27, 2014 08:51 PM
ziolo
Sep 12, 2010 07:43 AM
Brodie
Dec 1, 2007 11:43 AM
f155mph
Jun 25, 2007 10:07 PM
