electrical gremlins
Old Aug 11, 2023 | 08:32 PM
Originally Posted by mik
Ya, I pressed the button plenty, disconnected the battery cables and tried to reboot everything, didn't make the lights go off so it's garaged with a cable off.
You don't need to press the button "plenty"! Same concept of your home light switch, press once, on, press again, off.
Old Aug 11, 2023 | 09:51 PM
mik's Avatar
mik
I know, pushed in deactivates the lights completely, except mine are now staying on all the time, not good while driving at night. I suppose I could pull the bulbs but that really wonn't fix my problem.
Old Aug 14, 2023 | 09:32 AM
When you hook up the battery the H3 does a systems check and cycles the HVAC to confirm its settings. The PCM stores the last 300 ignition cycles power/no power. Installing a set of Battery Terminal Connectors is not very difficult. Patience is a virtue.
oceanbrave
Hummer H2 SUT
36
Oct 3, 2022 03:15 PM
deejaykaygee1
Mar 16, 2019 03:19 PM
atari800
Jan 31, 2016 07:30 PM
Spick
Jan 13, 2014 03:15 AM
grkthavma
Feb 4, 2011 05:07 PM
