New battery. Radio won't turn on
Old Nov 30, 2015 | 10:21 PM
deejaykaygee1's Avatar
Default New battery. Radio won't turn on
Hello I recently installed a new battery and after reconnecting the cables the radio does not work. The Display for time does turn on and off and when putting in a cd it loads but will not play. I have no display for Radio or stations. I was wondering if I need to reprogram the radio?
Old Nov 30, 2015 | 10:31 PM
happythree's Avatar
recheck connections, pins bent?...fuses?
Old Nov 30, 2015 | 11:29 PM
all fuses for radio and amp replaced but were not blown. Also want to add no door chimes.
Old Dec 1, 2015 | 08:12 AM
Disconnect the battery, wait at least 30 seconds, reconnect the battery, ground first.
BTW, does your truck still have the OEM Battery Terminal connectors????
If it does, they are complete CRAP, get rid of them and replace with a quality aftermarket set like Stingers or your favorite brand. There are gobs of threads on the topic of the need for aftermarket battery terminal connectors to replace the POS OEMs. It is not a matter of if, but when, they fail. Once replaced, the electrical Gremlins will pack up and look for the next dope with stock battery terminal connectors.
Old Mar 7, 2016 | 12:19 PM
126Andy's Avatar
Disconnect the neg battery terminal wait 1/2 hour reconnect and check the radio should reboot
Old Mar 7, 2016 | 03:10 PM
happythree's Avatar
cd loads, radio dont work. radio is defective.
Old Mar 7, 2016 | 04:19 PM
atari800's Avatar
I had that problem too when I changed batteries.
If the remove negative terminal for 30+ minutes doesnt work (it worked for me), get new battery terminals. Hummers can have possessed like electrical issues from lousy battery terminals.
Old Mar 7, 2016 | 05:11 PM
happythree's Avatar
batt in/out no problem.
when working on a 2 batt setup i unhooked the batt 10-15 times , never once had any problem of any kind, nothing
i have a disconnect now and can use it anytime with no trouble.
the radio is just a radio!!
Old Mar 8, 2016 | 07:59 AM
I'm fairly confident the guy that started this thread 3+ months ago doesn't need our help any longer??
Old Mar 8, 2016 | 09:33 AM
happythree's Avatar
ooops!
