Strange h2 issue - turns over but wont start
Old Jan 26, 2016 | 10:17 AM
atari800's Avatar
Default Strange h2 issue - turns over but wont start
Sunday morning, my battery was dead. I have one of those fancy battery chargers that can tell the percent of charge it is holding. So I tried to charge it, it bounced up and down between 10% and 25%.
I bought a new battery thinking, 8 year old battery is done with.
I popped in new battery and everything was good.
I went for a ride and something funny happened - all of my dashboard gauges went down but speedometer stayed on. My radio say "XM ERROR".
So I did a u-turn to head back home as this was still running. A few minutues later, all th3 gauges came back on and worked normally. I get home and power off h2. It started back up. I did it a few times. I thought it was "one of those things"
This morning, I went to jump in it and noticed my remote keylock didnt open door. So I manually unlocked it and the interior lights did not turn on. I try to start up h2, it turns over but doesnt start.
The passlock light does come on for a second and goes off when I turn it one (like a normal power up self test).
Any ideas what to check?
Old Jan 26, 2016 | 02:31 PM
atari800's Avatar
Ok
I decided to call a Mobile Mechanic. (Dan The Man)
I explained to him what I wrote above and took pictures on my phone of the battery terminals, and lights on the dash and stuff.
First he said "try another key" - possible passlock issue - no change
He said "unplug negative terminal for about 10 minutes or so and reconnect it"
I did this but had to call someone so it was disconnected for about 30 minutes.
Low and behold - the truck came back to life
So he says "drive it around local for a few days and see if the problem occurs again. It could be that I changed the battery fast enough ecm/bcm didnt discharge and may have been in a strange state.". Which sounds plausible as I swapped batteries in less than 3 minutes.
He says "The electronics on these types of vehicles can act almost possessed"
Anyways I will report result as time progresses
*maybe this will help someone
---===EDIT===---
This guy could have soaked me but was honest. I am not a super-duper car guru like a lot of the members here are so this was cool to me
Old Jan 27, 2016 | 02:45 AM
Gurba's Avatar
This issue also happens to Suburbans and Tahoes. Replacing the battery can cause strange electrical problems. My dads 05 Sub messed up the CC after unplugging the battery. I finally got it reset but it's really strange.
Old Jan 27, 2016 | 07:44 AM
atari800's Avatar
Well the issue still persist.
Grrr
I think I am dealership bound
Old Jan 30, 2016 | 05:26 PM
H2Miami's Avatar
Did you get it solved
Old Jan 31, 2016 | 07:47 AM
atari800's Avatar
Almost -it is at dealer.
They said "you got an aftermarket security system installed in here that shorted out and is causing the issues"
So... $800 to remove it
(this includes a detailing, fuel injector replacement (said they were pretty dirty), and flushing the differential (which I do remember when I bought the truck and wanted the fluids changed - they said they couldnt do the diff at that time)
Said everything else looked ok
I figured they would find something to UP the price. I dont care, mentally I envisioned a $5000 issue with all electronics needing to be replaced.
*Hope for the best - plan for the worst
I know, I know.... the mechanics in this forum are thinking "if he does it himself, he can save $775"
I like the peace of mind from a dealership giving the truck a 23 point inspection and fixing 2 issues
Old Jan 31, 2016 | 04:29 PM
H2Miami's Avatar
Hopefully mine is at the same . I do also have an aftermarket alarm (cliford)
I was installing a led lights and made a mistake connecting the power to the Drl . I assume the install of the led cause the issue maybe it mess with the alarm
I will post after the dealer gave me an answer
Old Jan 31, 2016 | 07:30 PM
atari800's Avatar
Good luck. Update with results
simota1
Nov 24, 2021 12:45 PM
davewood767
Hummer H1
Sep 20, 2019 07:50 AM
z_pad_69
Apr 18, 2013 02:53 PM
Old Trooper
May 17, 2011 06:00 PM
FLH378
Aug 16, 2010 11:24 AM
