2006 H3 stab control, heater actuator, passlock: c0240 p2122
Old Nov 4, 2019 | 05:34 PM
  #41
Whitemountainh3's Avatar
Did you clean the connector and contacts on the switch?
You mean the blue connector going into the black plastic part of the switch? I did clean that twice. Is there a benefit to pulling the black part and cleaning inside where it makes contact with the tumbler? Its only happened three times in the past couple months. One thing I did notice when it happened last was that the key seemed to stick a little when I went to turn it before it wouldn't start.
Also, still no problems on the stability failure front! Very likely was the battery or the body ground (one was a little loose). Still in the wait and see phase on it though.
One of the morals of this story I guess is don't trust a 18 year old kid at the parts store telling you your battery tests fine...
Old Nov 4, 2019 | 06:06 PM
  #42
Yes, clean the contacts in the switch!
Old Nov 5, 2019 | 02:13 PM
  #43
Welp, reduced power happened again. This time the only code is P2122.
I’ve cleaned the connectors at least twice. Is there a way to test the tps and pps to see which one may be acting up?
Old Nov 5, 2019 | 04:13 PM
  #44
I just found a small vacuum leak at the throttle body. Very very small leak but the clip on the hose was broken and I think I could hear a bit of air escaping. Going to temporarily seal it, any chance this could be causing a misread on throttle position for the computer?
Ceronv
Dec 27, 2017 02:35 PM
langj
Nov 10, 2016 09:55 AM
vacman
Feb 19, 2016 12:51 PM
Thorsz
Apr 27, 2015 12:10 PM
bscathey701019
Oct 14, 2013 07:23 AM
