2006 H3 stab control, heater actuator, passlock: c0240 p2122
Old Oct 30, 2019 | 03:20 PM
  #31
Whitemountainh3's Avatar
Ok, battery tests at 12.1V off and 14.2V on while all accessories are on. I’m assuming that’s close enough?
Are there any ground straps besides the two near the battery I should check?
Old Oct 30, 2019 | 03:39 PM
  #32
650Hawk's Avatar
Your battery is low; 12.1 volts is only a 50% state of charge.
Old Oct 30, 2019 | 03:42 PM
  #33
X2 Battery!
Old Oct 30, 2019 | 04:02 PM
  #34
Important to get a good quality battery ,also eliminate the AM wiring you found.
Old Oct 30, 2019 | 05:43 PM
  #35
Ok, bought a new Optima battery, installed it. Cleared codes. Removed body grounds cleaned and tightened. I will say that it seems to run smoother so far, but that could be in my head...
Old Oct 30, 2019 | 06:18 PM
  #36
Monitor the voltage. Now you can get
led volt meter led volt meter
with usb support.
Old Oct 30, 2019 | 06:32 PM
  #37
Monitor the voltage. Now you can get led volt meter with usb support.
I got a Wifi OBD II adaptor and am using car scanner on IOS to read codes and other info. Just got it and love it so far!
Old Oct 30, 2019 | 06:51 PM
  #38
Yes, however you can see the battery voltage inside, before you take action. Min. 12.5v resting/ Min. 14.5v charging/ Min. 11v starting.
Old Nov 2, 2019 | 09:21 PM
  #39
Update: driven around 100 miles since the battery swap and ground strap cleaning and no problems yet. No codes. Keeping my fingers crossed!
Did get the passlock problem yesterday morning again, so guess I’ll be doing the ignition switch replacement and a new key as well...
Old Nov 3, 2019 | 09:07 AM
  #40
Did you clean the connector and contacts on the switch?
