H2 Key Fob Replacement Programming
Old Jan 15, 2023 | 02:30 PM
you might have a broken wire in the door harness. usually in the rubber boot going into the door
Old Jan 15, 2023 | 06:01 PM
Thats definitely the problem..... the PDM (passenger door module / window switch) is the keyless entry receiver.
Old Jan 15, 2023 | 06:04 PM
PGI Conch's Avatar
Ah ha! Eureka. And would that be somewhere inside the door itself? Or in the xab somewhere? Thanks....
Old Jan 16, 2023 | 10:22 AM
Yes it is in the door (panel) the PDM is the actual window switch module (and is also the wireless receiver module). If the entire door is dead then either that module itself has died or something is wrong with the power to it.
Old Jan 16, 2023 | 12:57 PM
PGI Conch's Avatar
Found it. Passenger Door Module power fuse was either not pushed in correctly or something in/around that fuse block (inside to left of dash) area was loose. Pulled the fuse to check it and found it to be OK. Reinstalled the fuse, pushed on the wire loom connector next to it, and everything worked. Voila! That also solv3d my problem with the FOB not working as the remote control is located in the passenger door module. Yea!
PGI Conch's Avatar
Thanks to all for the feedback. All good now. See my reply above.
Old Jan 16, 2023 | 01:24 PM
Glad to hear it was an easy fix!
Chris Tregoning
Oct 9, 2021 03:11 AM
Boatbuilder41
Mar 23, 2021 08:53 AM
therealdougkelly
Aug 4, 2020 02:35 PM
cryscor
Apr 11, 2009 12:38 PM
finall
Dec 20, 2008 11:30 PM
