H2 Key fob options
Old May 16, 2017 | 06:05 PM
therealdougkelly's Avatar
Default H2 Key fob options
Is there a flip Key available somewhere on the www for the H2?
Or any other options for that matter?
Every vehicle I've owned has the Key/fob built into a single unit. Seems like there should be something on the market to combine the two and I suspect someone on here has one. Give me some details!!
Old May 17, 2017 | 04:40 PM
dontheo55's Avatar
Push button start
Old May 20, 2017 | 02:59 PM
iggieX's Avatar
I saw one on ebay for about $30+ bucks. Its in my cart, just haven't bought it yet.
Old May 20, 2017 | 03:03 PM
iggieX's Avatar
Here is the Key I am referring to
Old May 20, 2017 | 08:19 PM
Thanks for the info. The price seems fairly reasonable. Hopefully the dealership doesn't rape me to have it programmed.
Old May 21, 2017 | 10:58 AM
Synthetickiller's Avatar
You can program key fobs at home.
2003-2007
2008/2009
I've done this with my 09 many times.
I might end up getting the key cut if I can program this one.
Old May 22, 2017 | 04:44 AM
Baldfox's Avatar
i did see there was an upgraded Key for our H2s once. I think it gave you remote status, extended range, TPMS etc etc... Anyone ever go down that route ?
Old May 22, 2017 | 08:18 AM
Here's a pic:
These seem to only be for the 2008/2009 models. I think you have to go viper or some other third party if you want remote start, etc.
Here's some links ($145 and $243 respectively). No clue what the difference is or what the compatibility is.
Transmitter Pkg | Genuine GM | 19171129 : GM Parts Direct: Your direct source for Genuine GM Parts
Transmitter Pkg | Genuine GM | 17802087 : GM Parts Direct: Your direct source for Genuine GM Parts
My best guess is the cheap link is the remote only, then expensive link is the entire package. Entire package is this:
This one is OOS/EOL.
Transmitter Pkg | Genuine GM | 19244165 : GM Parts Direct: Your direct source for Genuine GM Parts
I don't really see the benefit. It's another electronic device to break. Other than extended range for starting your vehicle on a cold/hot day, I don't see much of a benefit, honestly.
Old May 22, 2017 | 08:42 PM
2003-2007
2008/2009
Thanks for the helpful info!! Also, just realized that the item description on eBay (for the flip Key) there is a link for programming instructions.
Old May 23, 2017 | 01:51 AM
Baldfox's Avatar
I guess i liked the fact that you could monitor the status of the car from afar as well as check the TPMS readings. I am not sure if my h2 came with TPMS, and have never known how to check etc...
