H2 Key fob options
Is there a flip Key available somewhere on the www for the H2?
Or any other options for that matter? Every vehicle I've owned has the Key/fob built into a single unit. Seems like there should be something on the market to combine the two and I suspect someone on here has one. Give me some details!! |
Push button start
I saw one on ebay for about $30+ bucks. Its in my cart, just haven't bought it yet.
You can program key fobs at home.
2003-2007 2008/2009 I've done this with my 09 many times. I might end up getting the key cut if I can program this one. |
i did see there was an upgraded Key for our H2s once. I think it gave you remote status, extended range, TPMS etc etc... Anyone ever go down that route ?
Here's a pic:
These seem to only be for the 2008/2009 models. I think you have to go viper or some other third party if you want remote start, etc. http://farm4.static.flickr.com/3088/...e5f0bbf272.jpg Here's some links ($145 and $243 respectively). No clue what the difference is or what the compatibility is. Transmitter Pkg | Genuine GM | 19171129 : GM Parts Direct: Your direct source for Genuine GM Parts Transmitter Pkg | Genuine GM | 17802087 : GM Parts Direct: Your direct source for Genuine GM Parts My best guess is the cheap link is the remote only, then expensive link is the entire package. Entire package is this: https://images.dad-n-lad.com/GM_17802087_Primary.jpg This one is OOS/EOL. Transmitter Pkg | Genuine GM | 19244165 : GM Parts Direct: Your direct source for Genuine GM Parts I don't really see the benefit. It's another electronic device to break. Other than extended range for starting your vehicle on a cold/hot day, I don't see much of a benefit, honestly. |
I guess i liked the fact that you could monitor the status of the car from afar as well as check the TPMS readings. I am not sure if my h2 came with TPMS, and have never known how to check etc...
