Need Help With Wheel Size
Old May 12, 2011 | 08:24 AM
CodyB's Avatar
Default Need Help With Wheel Size
Can someone recommend a 17" wheel width, offset and backspacing for some 33x12.5-17 tires so they wont rub or stick out to far? I would like to get some good sidewall bubble if that makes a difference (narrower rim?)... I like the balloon tire look.. This is for a 2009 H3..
This is for a pavement princess that will not see any offroading..
Thanks for any help!!
Old May 12, 2011 | 01:49 PM
Timgco's Avatar
What you need: 17 x 9/ 5.71 back space/ +18 offset/ hub centric
Wheels I have fitted with 35's:
XD Addict
XD Hoss
You will need to order them in Hub Centric or get the Hub centric rings. 35's fit great and did not stick way out. They are a wider stance and slightly outward more, but not much. Since you are using 33's, you will have more than enough room at yur wheel wells and swaybar.
Old May 12, 2011 | 02:12 PM
CodyB's Avatar
XD Addict
XD Hoss
Great, thanks for the info!!!
I was going to go with 35's but since this is my wifes truck, I figure I would keep them at 33" since she already complains about having to climb in my dually that I just put 37"s on
Thanks again!
Old May 12, 2011 | 06:38 PM
Weston's Avatar
Can i fit these on 35-12.5 Bolt Pattern: 6 on 5.5 Diameter: 22.00 Width: 12.00 Backspace: 4.77 Offset: -44.00 mm
Old May 12, 2011 | 06:40 PM
Weston's Avatar
lol after reading it i meant can i fit those rims on the H3 after the the leveling kit..
Old May 13, 2011 | 07:11 PM
CamG243's Avatar
I just got my 285s on Dick Cepek Torques Not going to lie it looks amazing the 0 offset looks mean as none other. No Rubbing or anything il post pics later.
Hummer79
Jan 7, 2013 11:28 PM
davyo
Dec 6, 2012 11:27 AM
kav315
Nov 23, 2012 12:01 AM
lucky19942001
Apr 11, 2008 08:36 AM
davyo
Aug 2, 2006 07:04 AM
