need tire size help
Old Apr 10, 2008 | 10:56 PM
lucky19942001's Avatar
Default need tire size help
hey guys need some help here never been a tire guy or really anything until i got my hummer and when i bought it it came with the tire and rims so i have been looking for a upgrade something thats a little tougher and meaner looking and been checking out nitto, well when i put my tire size in it comes back with 2 out of the 4 tires. well i have now a 275/60/20 and i googled that a try to convert it and it comes back at 33x10.8x20 well i cant find a tire that matches that at all i have seen a 33x12.5x20 so theres my problem. if i want the mud grappler they dont show it in 275/60/20 but show it in 33x12.5x20 thought it was the same but i have no idea. if any one can explain better to me. what can i put on a 20 inch rim same tire or can i swap so if any1 can help the confused i would appreciate it
[IMG]local://upfiles/4035/B792F5BB389F40DE89981AE4E082781D.jpg[/IMG]
[IMG]local://upfiles/4035/34FFAC379E4E483BB0A30B0F1593A052.jpg[/IMG]
[IMG]local://upfiles/4035/0263E51D7A244AEEB62757BB2D4AB5F7.jpg[/IMG]
Old Apr 10, 2008 | 11:44 PM
alrock's Avatar
Default RE: need tire size help
Your tire sizes are going to be metric, i.e. 285/75-16. If you want to go to a 20" you can easily do a 275/55-20 or 285/55-20. Take a look on websites like tires.com for help. Most tires aren't listed in the older format like 33x12.5x20 any more.
If you are going to go offroading I wouldn't recommend going above an 18" rim.
Old Apr 11, 2008 | 12:44 AM
not gona go off roading just wana keep the 20 inch rim i have now but put on a tire with a little better look.so can i put on any tire as long as its for a 20in rim like i said i have a 275/60/20 now. so can i change to anything ending in 20 ir do i need to keep the middle number the same or what
Old Apr 11, 2008 | 07:23 AM
TexH3's Avatar
275/60-20
The first number is thetire width in millimeters. The second number is the sidewall height expressed as a percentage of the tire width (or aspect ratio). The last number is the wheel/rim diameter in inches.
The middle number will be smaller for lower profile tires. Also, you are limited on how wide a tire you can put on a given rim.
Old Apr 11, 2008 | 08:36 AM
webslinger1977's Avatar
metric to standard 1st#/25.4x2nd#x2+3rd#= highth 1st#/25.4=width
I think the Mud grappler only comes in standard sizes the 33x12.50 should fit fine it will just be a little wider.
305/55/20 would be a good size it the terra grappler I think.
Andreas_Sweden
Mar 19, 2025 12:16 PM
Bert
Sep 24, 2013 10:55 AM
Hummer79
Jan 7, 2013 11:28 PM
rudy_1117
Jun 10, 2009 07:29 PM
IN2deep
Oct 15, 2007 09:23 PM
