Encoder/ actuator motor replacement
Edit: As pointed out by TAINTER below; completely disregard this post of mine.
The encoder motor has absolutely ZERO to do with 4Hi lock/4Hi unlock/4 Low, not sure why you replaced that for a 4wd problem. Encoder motor is for the transmission only; PRND321. Problems with the 4wd mode (4HI, 4HI Locke, 4LOW Lock) is the transfer case (or the buttons on the dash), NOT the transmission.
People/parts websites/forums/etc. call them encoders/actuators/4x4controller/4x4switcher/etc.
The actuator with encoder Motor (which is the technical name) moves the selector shaft in the Tcase to the desired Tcase range.
A few examples Below,
GM PARTS: 89059688 ACTUATOR,TRFER CASE FOUR WHL DRV(INCLS ENCODER MOTOR)(ACDelco #89059688). ACTUATOR,TRFER CASE FOUR WHL DRV(INCLS ENCODER MOTOR)(REF TSB 09-04-21-005C FOR INSTALLATION INSTRUCTIONS)(ACDelco #89059688).
AMAZON: ACDelco 89059688 GM Original Equipment Transfer Case Four Wheel Drive Actuator with Encoder Motor
eBay: Hummer GM OEM 06-10 H3 Transfer Case-Actuator Shift Motor 89059688
Hawk, actually the OP is correct in using the encoder motor term.
My H3 is stuck in 4 Low. I pulled the encoder off the Trans Case and confirm the motor does not move when 4x4 buttons pressed.
1. Anyone know how to 'test" an encoder motor.
2. Any ideas as to what would prevent an encoder motor from receiving power?
Thank you
Thank you
Ask your question ONE TIME and WAIT for responses.
Solved...was a sized encoder motor.
igolf2
01-28-2019 12:32 PM
Happy Hummer
03-10-2018 10:34 PM
