Encoder/ actuator motor replacement
Old Jun 21, 2019 | 03:37 PM
Baja's Avatar
I can’t do that by myself how much does a repair like that cost ?
Old Jun 22, 2019 | 10:19 PM
No idea. I do my own wrenching
Old Jun 23, 2019 | 06:34 AM
Baja's Avatar
Thanks fo all the info
Old Jun 23, 2019 | 07:01 AM
Search "plastic shift fork" here. Should be a ton of posts. Some may have prices they paid?
Old Jul 11, 2019 | 05:42 PM
650Hawk's Avatar
Cool
Originally Posted by Baja
Change the encoder motor, it still won’t go into four high while moving ,It will only go to foru high when I first start the truck and it’s in park . Any suggestions
The encoder motor has absolutely ZERO to do with 4Hi lock/4Hi unlock/4 Low, not sure why you replaced that for a 4wd problem. Encoder motor is for the transmission only; PRND321. Problems with the 4wd mode (4HI, 4HI Locke, 4LOW Lock) is the transfer case (or the buttons on the dash), NOT the transmission.
Edit: As pointed out by TAINTER below; completely disregard this post of mine.
Old Jul 12, 2019 | 06:00 AM
Hawk, actually the OP is correct in using the encoder motor term.
People/parts websites/forums/etc. call them encoders/actuators/4x4controller/4x4switcher/etc.
The actuator with encoder Motor (which is the technical name) moves the selector shaft in the Tcase to the desired Tcase range.
A few examples Below,
GM PARTS: 89059688 ACTUATOR,TRFER CASE FOUR WHL DRV(INCLS ENCODER MOTOR)(ACDelco #89059688). ACTUATOR,TRFER CASE FOUR WHL DRV(INCLS ENCODER MOTOR)(REF TSB 09-04-21-005C FOR INSTALLATION INSTRUCTIONS)(ACDelco #89059688).
AMAZON: ACDelco 89059688 GM Original Equipment Transfer Case Four Wheel Drive Actuator with Encoder Motor
eBay: Hummer GM OEM 06-10 H3 Transfer Case-Actuator Shift Motor 89059688
Old Jul 12, 2019 | 03:19 PM
650Hawk's Avatar
Ooops, you are correct; I stand corrected. Wow, not sure why I got that mixed up...I'll claim a brain fart (that's my story, and I'm sticking to it)!
Old Apr 9, 2020 | 08:43 PM
gwarrend's Avatar
My H3 is stuck in 4 Low. I pulled the encoder off the Trans Case and confirm the motor does not move when 4x4 buttons pressed.
1. Anyone know how to 'test" an encoder motor.
2. Any ideas as to what would prevent an encoder motor from receiving power?
Thank you
Old Apr 13, 2020 | 10:17 AM
Thank you
Ask your question ONE TIME and WAIT for responses.
Old Apr 13, 2020 | 12:17 PM
gwarrend's Avatar
Thank you
Solved...was a sized encoder motor.
igolf2
Jan 28, 2019 12:32 PM
Happy Hummer
Mar 10, 2018 10:34 PM
Knightblade
Nov 16, 2017 09:51 AM
altopolski
Aug 11, 2014 11:10 AM
altopolski
Aug 10, 2014 01:04 PM
