Encoder/ actuator motor replacement
Old Jun 6, 2019 | 05:35 PM
Baja's Avatar
Default Encoder/ actuator motor replacement
Does the encoder/actuator motor for the four-wheel-drive transfer case need to be programmed or is there any special way to install the motor thanks in advance
Old Jun 7, 2019 | 08:59 AM
No Programming, make sure both the encoder and Tcase are in 4HI unlocked before mating them.
Old Jun 7, 2019 | 03:50 PM
Baja's Avatar
Sorry I’m new to the hummer what do you mean by 4 high unlock right now it currently won’t move out of that standard all wheel drive mode when I push the for high button it just flashes if I reset it for the code reader it will let me put it in if I’m in park
Old Jun 8, 2019 | 08:21 AM
Baja's Avatar
I appreciate the answer Tainter I just also read about putting the transmission in neutral so I’m just getting mixed answers
Old Jun 10, 2019 | 09:27 AM
Why the Funk would you need the transmission in neutral!!!!
I read about some guy with a spinning spider monkey on his dick but I used "common scene" and did not do that either.
The transmission is an independent entity of the transfer case. Set the Tcase control to 4 HI unlocked, turn off truck, disconnect battery, block at least 2 opposite tires, crawl under the H3, remove the wire connector to the encoder, remove 3 bolts on the encoder, replace the old encoder with new encoder. install 3 bolts back into the encoder, reinstall the harness, reconnect battery, turn key forward, test the new encoder by switching from 4 HI unlocked to 4 Hi Locked several times.
If you are not sure what 4 HI unlocked is you shouldn't be replacing Sheet on your H3.
If you can NOT get out of 4 HI unlocked, it's probably not the encoder. It's going to be a shift fork issue 90% of the time.
Old Jun 12, 2019 | 10:13 AM
Baja's Avatar
Thanks tainter I was just getting mixed answers from different people in different forms putting it in neutral not putting it in neutral leaving and park yours is the best answer and I really appreciate it I thank you very much only reason I have a question on the four high on lock was whether or not to actuate the switch or manually put it in for high once the encoder motor was out it will go into 4high once I start it and I push the four high button but it will not do it on the fly
Old Jun 12, 2019 | 01:47 PM
650Hawk's Avatar
Originally Posted by Baja
...it it will go into 4high once I start it and I push the four high button but it will not do it on the fly
Keep in mind that the H3 transfer case will not switch from 4 HI to 4 HI Lock (or back) if you are driving faster than 45mph.
Old Jun 13, 2019 | 07:30 AM
No problem, Sorry about the monkey stuff.
I just get frustrated with all of the bad and incorrect information on Bookface/social media. No forum said neutral.
Please, use punctuation. It's very had to know when a sentence ends and a new one starts.
"If you can NOT get out of 4 HI unlocked, it's probably not the encoder. It's going to be a shift fork issue 90% of the time."
Old Jun 21, 2019 | 06:56 AM
Baja's Avatar
Change the encoder motor, it still won’t go into four high while moving ,It will only go to foru high when I first start the truck and it’s in park . Any suggestions
Old Jun 21, 2019 | 08:12 AM
Shift fork!!!
