Service charge system ?
Old Jun 3, 2020 | 02:03 PM
  #31
NFS's Avatar
NFS
18 is spare, 45 is auxiliary power. UHFB
well I have after market aux so I should be good well great! It’s all good to go! Thank you so much h for your help hummerz
Old Sep 13, 2020 | 07:33 AM
  #32
MaximktVI's Avatar
Default Similar issue
You need a scanner that will scan Generator Battery Control Module (GBCM)
Whatever,
I will guess the code B1390 and/or B1492?
Test at Under Hood Fuse Block (UHFB) fuse 32.
Test at C125 terminal 16 Orange wire.
Trace wire from C125 to GBCM terminal C, look for open wire.
i am using an BT Autel scanner with GM package and getting a B1390 error code. In live mode My battery voltage signal zero. I have yet to remove the fuse block as I’m not sure if it’s above my skill level?
Screenshot of GBCM results in live view
Old Sep 13, 2020 | 10:24 AM
  #33
NFS's Avatar
NFS
thank you for your reply, we figured it out . It was a missing fuse under the hood
NFS
Feb 27, 2020 09:22 PM
yellowhummerh3
May 25, 2018 05:48 AM
lostsoul77
Mar 6, 2018 10:54 AM
h3carlos
Dec 2, 2016 08:25 AM
H3I5
Oct 9, 2012 08:15 PM
