Service charge system ?
Old Jun 2, 2020 | 03:53 PM
  #21
NFS's Avatar
NFS
Look at the wiring diagram posted above, #32 fuse is the REGULATED VOLTAGE CONTROL(RVC) VSENSE+.
Get your meter out and check voltage at the fuse and check terminal C(A-orange, B-grey, C-orange) :
okay thank you sir. I’ll check that and the other wires you told me about after work and post the results
Old Jun 2, 2020 | 05:43 PM
  #22
NFS's Avatar
NFS
Default Fixed!!!
Yes, you have to pull them out of the loom to inspect (pic from internet, pointer showing damage to repair):
The GBCM is on the negative battery cable:
so here is what I found! I checked the fuses number 32 and there was no fuse!!!! So I put a A10 there the msg went away!!! The stupid shop who took off the system must have took the fuse and never put it back! The msg went away. I’ll drive it for few days and see if it stays! Thank you so much Hummerz and everyone who helped me! You guys are life savers!
Old Jun 2, 2020 | 06:03 PM
  #23
Wow, that was easy. Just to confirm no damage done and GBCM has control again, check voltage at idle, and post results.
Old Jun 2, 2020 | 06:55 PM
  #24
NFS's Avatar
NFS
resting is 12.78
when first start it’s 15.36
i waited a good 10 mins with everything off include the running lights radio and everything
and I got 12.91
Old Jun 2, 2020 | 08:30 PM
  #25
resting is 12.78
and I got 12.91
GBCM back in control.
Old Jun 2, 2020 | 11:24 PM
  #26
NFS's Avatar
NFS
that’s awesome! Thanks a lot hummerz
Old Jun 3, 2020 | 11:36 AM
  #27
NFS's Avatar
NFS
Put a meter on your battery, should be @12.5v+resting. While keeping the meter attached(clamps or stick probes in terminals) turn off all accessories and start it up. You should get 15v+ on startup, then after a few minutes, should drop to 13.5v.
Post the results.
hey hummerz would you be able to send me a pic of your fuse box like a good pic from the top I just want to make sure I am not missing any other fuses lol
Old Jun 3, 2020 | 11:55 AM
  #28
Old Jun 3, 2020 | 12:12 PM
  #29
NFS's Avatar
NFS
so there was no 15 in number 18 I installed 15 and my number 45 I have 20 instead of 30. Will that be a problem ?
Old Jun 3, 2020 | 01:35 PM
  #30
18 is spare, 45 is auxiliary power. UHFB
