Parts / advise
Old Nov 13, 2024 | 01:00 PM
Geoanimal's Avatar
Default Parts / advise
Looking for a few part and also maybe advise or an idea for a black 2006 H3. It is my daughter’s pride and joy. And the parts are for her rig.
Looking for:
chrome/stainless steel locking fuel door
a spare tire cover either black OR paintable (maybe the 50/50 hard cover)
A repair book
looking for advise or idea:
on the sun roof the tubes continue to get clogged even with regular cleaning and water ends up on either the passenger or drivers floor. Once it had water on the fuse box up under the steering wheel. Had the like “X” grommet drilled out and will still leak. Yea this is with the sun roof closed.
Old Nov 14, 2024 | 06:58 AM
Happy Hummer's Avatar
Looking for:
A repair book
https://www.google.com/search?q=humm...obile&ie=UTF-8
https://www.google.com/search?q=humm...t=gws-wiz-serp
As for sun roof... test with garden hose and verify where leak is coming from.
Old Nov 14, 2024 | 07:19 AM
Might not be a sunroof leak. windshield seal, cowl leak, etc.
Water hose test as mentioned above.
Old Nov 14, 2024 | 09:18 AM
After cleaning/flushing Sunroof Drains, finish with a dose of Shower Clean to keep water flowing.
Be sure to check the other sources of leaks above.
Just so you know, the DefenderWorx type locking Fuel door are just screwed or riveted to the fender fuel filler and can be ripped off without much effort. Not much security to be gained from those. I bought an 09 Alpha from AR and even though a southern truck, the lock was so corroded it permanently stuck and I ditched that for the OEM Chrome Fuel Door (no lock).
Old Nov 15, 2024 | 09:31 AM
Geoanimal's Avatar
Default Thanks
Thank you guys for the tid bits of knowledge. I will let her know.
jhall
Feb 17, 2023 01:46 PM
omedus
Aug 18, 2021 01:39 PM
Daniel Huston
Nov 18, 2016 07:02 PM
Synthetickiller
Sep 16, 2015 05:46 PM
budryzer
Feb 16, 2014 07:12 AM
