Overheating is STILL a mystery
Old Feb 5, 2023 | 07:57 PM
  #21
Kameron S's Avatar
DO NOT run engine, repair the coolant leak, drain/refill engine oil, prevent Spun Bearings
can’t find the leak.. brand new everything
Old Feb 7, 2023 | 04:31 PM
  #22
650Hawk's Avatar
Originally Posted by Kameron S
UPDATE:Just let in run for 10 min in the driveway. Cold engine and no drips of any kind (see pic) , after 10 min, warm engine oil oozing from pan (see pic) and milkshake on oil dipstick and under fill cap.
headgasket was replaced 50-ish miles ago.
Headgasket is leaking water/coolant into the oil. Either that or you have a cracked block. There's a reason that "shade tree" mechanics don't actually do mechanical work for a living.
Old Feb 18, 2023 | 03:16 PM
  #23
Kameron S's Avatar
sooo… had it towed to a shop. They said to diagnose the overheating and milkshake it will be $2,800 bc “ it probably needs a new engine which will be around $10k.”
Someone on this thread said that the previous mechanic could have put the new head gasket on wrong causing it to overheat. Would that also cause the milkshake or is the milkshake a DEFINITE sign of a cracked block? Why is the block cracked? It wasn’t overheating until until mechanic put the headgasket on.
What else could be wrong? Is this for sure a major issue with milkshake and overheating?
Is there a way to see if the headgasket is on upside down without paying the shop $2800 to determine this?
What would you all do? Legit, helpful recommendations please. We don’t want to sell it.
thanks in advance
Old Feb 18, 2023 | 06:29 PM
  #24
thanks in advance
LOOK HERE FOR A CHEAP TESTER>>>>>Combustion Leak Detector
HOW TO:
Old Feb 19, 2023 | 10:52 AM
  #25
Kameron S's Avatar
Cool. Thanks for that! Is this test accurate if there is only water in the radiator and no more antifreeze?
Old Feb 19, 2023 | 11:32 AM
  #26
Disel's Avatar
Originally Posted by nmh3
^^^ Вот. Здесь вы можете увидеть, как выглядит прокладка (наложенная на оригинал), когда она перевернута. Почти все остается таким же, за исключением пары областей, которые неуклюжий/не обращающий внимания механик мог бы «приспособить», если бы достаточно постарался.
если перевернуть прокладку, то ОЖ из помпы течь не будет. Двигатель сразу перегреется. Только глупый механик мог допустить такую ​​ошибку.
Old Feb 19, 2023 | 11:37 AM
  #27
Tester fluid changes color when exposed to combustion gases from radiator.
  #28
Disel's Avatar
thanks in advance
You need to check if the pump is pumping. If the gasket is turned over, the pump will not pump. Engine for repair.
socalhummer
Feb 6, 2023 09:31 AM
H32006
Dec 28, 2021 09:43 AM
ENASNI
May 9, 2018 08:00 AM
jcoats3
Jan 11, 2014 12:41 PM
melloyello
Apr 6, 2011 10:55 AM
