Coolant completely dry - something not right
Old Jul 6, 2016 | 12:15 PM
socalhummer's Avatar
Default Coolant completely dry - something not right
Hello everyone. I posted awhile ago about needing a new cat converter. Three months ago, I had the following done at the dealer:
Transfercase mount nuts MISSING
Right Side Cat Converter
Spark Plugs and wires
Perform Recall
Brakes:
Throttle Body Service
Immediately after I picked up my H3, I smelled a "sweet" smell every time I drive it. I was told the new cat converter could be causing it. However, after 3 months, it was getting worse. I was getting ready to take it to the desert and the coolant was completely dry. When my husband put more in, it leaked out into the driveway and we ended up taking the FJ. When we got home, we refilled it and it leaked a slight bit. I took it to work today, and it's running rough but not hot. My car has always burned a lot of oil and runs around 3/4 to the red on the temp gauge. Any suggestions why my coolant is out? Where I may have a leak or if the dealer did something because that's when the smell started?
Old Jul 6, 2016 | 04:28 PM
650Hawk's Avatar
"It leaked out into the driveway"...where is it leaking from?
Old Jul 7, 2016 | 07:30 AM
rsc's Avatar
rsc
Couple of things it could be from cheapest to most expensive-
radiator hoses
overflow catch tank
radiator (core or tanks, either way its a new radiator)
head gasket
cracked head
Old Jul 7, 2016 | 08:53 AM
650Hawk's Avatar
heater hose(s)
heater core
water pump
Old Jul 7, 2016 | 08:54 AM
happythree's Avatar
Default good news,,,bad news..
mine was the water pump, quite a job
Old Jul 7, 2016 | 11:09 AM
Leaking on each end of big plate in front. There is a smaller spit on the passsenger side front and a larger spot on the drivers side. It looks like the overflow ran out and dripped out both sides of the car.
Attached Thumbnails Coolant completely dry - something not right-image.png   Coolant completely dry - something not right-image.jpeg
Old Jul 7, 2016 | 03:32 PM
Default I put up pics, now I hear a hissing noise
I posted pictures. I hear a hissing noise now. Please ...any ideas before I get ripped off by a mechanic. Thank you!
Old Jul 7, 2016 | 09:14 PM
It's the radiator! How much will that typically run?
Old Jul 8, 2016 | 06:03 AM
rsc's Avatar
rsc
heater core
Oooh! Go straight for the big money! The whole dash has to come out.
Old Jul 8, 2016 | 06:04 AM
rsc's Avatar
rsc
I bought a Silla replacement off eBay and installed it myself. $179 plus some coolant and my own time. At the time folks were getting it done for about $900 at the dealership. hahahaha
