Hummer won’t start.
Old Jan 27, 2023 | 04:49 PM
willwhitleyusa@gmail.com's Avatar
Default Hummer won’t start.
Hummer won’t start. Here’s what I know.
-it’s in park. Verified by checking the disengage switch under the plastic. To add; the transmission linkage is fine.
-backup camera is on, so I believe the computer thinks it’s in reverse, but no reverse lights.
-keys were stuck, but I popped the column to release the switch to take them out.
-when attempting to start, here’s what happens.
1. key in, turn, check engine light on, and audible fuel pump starts.
2. turn for ignition. Nothing. No clicks. No indication the starter solenoid is doing anything.
what am I missing.
Old Jan 27, 2023 | 05:54 PM
what am I missing.
Old Jan 30, 2023 | 09:32 AM
What is the resting voltage of your Battery? When you key gets stuck in the ignition, that is GM's message to you that the battery is dead.
Are you still trying to use the Crappy Azzed OEM Battery Terminal Connectors? If so hack them off immediately and replace with a quality aftermarket set like Stingers or your favorite brand.
KING TANK
Nov 9, 2017 09:19 AM
AR15wheeler
Apr 20, 2015 09:29 PM
jchummer
Dec 28, 2012 06:08 PM
InfantryH2
Jan 23, 2012 11:53 AM
BobsHummer
Apr 11, 2011 06:32 PM
