help asap outta town oil light keeps coming on
Old Apr 12, 2023 | 10:11 PM
  #71
Nikal's Avatar
Originally Posted by Millertime045
yk what I mean it’s been hell of a week so based off what he said what you think
I think you need to find another reputable repair shop. A good shop has access and can look up the specs for your vehicle. If the test they did was accurate and they found 12 psi @ 1200 rpms, and if what Hummerz shows on that spec sheet of 12 psi @ 1200 rpm is correct. Then your engine is not “Gone” as your mechanic said. They should have known this.
Im not sure where you’re located, but you need to find another mechanic. You’re spending allot of money with the wrong guy. You’d be better off spending that money at a Chevy dealership repair center, if you can’t find another quality shop.
Old Apr 12, 2023 | 10:14 PM
  #72
Millertime045's Avatar
very very very small town lol like few shops around here most backed up weeks because can’t get anybody to work
Old Apr 13, 2023 | 09:20 AM
  #73
Originally Posted by Disel
Why is the engine temperature so high? temperature needle should be no higher than the middle
The dash Temp gauge in the pic is NORMAL, anything under 3/4 is NORMAL because the dash gauges are basically an idiot light with a needle. You need to read the actual temp with a scan gauge to know what the dash gauge is really telling you.
Old Apr 13, 2023 | 09:21 AM
  #74
They can't get anybody to work because they likely pay crap and capable mechanics do not have to work for peanuts so they go elsewhere. Just like you should. Obviously they are INCOMPETENT based upon what you are saying your were told by those BOZOS. There is no general rule of 10psi/100 rpm, complete BS! Like the internet, there is some good information, there is some BS, and there is some good BS. You have to have the ability to understand which is which.
Old Apr 13, 2023 | 09:47 AM
  #75
info I got said motor is gone
Old Apr 13, 2023 | 06:14 PM
  #76
"Info you got"?
First and foremost; Oil pressure should be checked @OPERATING TEMPERATURE!
#2 Engine oil pressure should be:1psi per 100rpm
Old Apr 13, 2023 | 06:22 PM
  #77
"Info you got"?
they actually do good work but imo they rushed that day had death in family so this info I have go by lol oil light still coming on steady as well
Old Apr 13, 2023 | 06:40 PM
  #78
Whatever...BTW, You didn't answer my question posted above:
Oil light off @ startup idling in park?
Old Apr 13, 2023 | 07:03 PM
  #79
Send questions again it’s hard keep up like 80 post on here they lag when I go threw them the oil light comes on warned up maybe 5-10 drive when you first crank it nothing pops up immediately
Old Apr 13, 2023 | 07:16 PM
  #80
Clogged Oil Passages in the Engine.
