engine swap
Old Nov 17, 2024 | 10:31 PM
AymenB's Avatar
Red face engine swap
Hello, I bought a 2008 Hummer H3 that someone swapped a 2007 engine into
i rebuild it as new but the only problem is that the engine come with 2 camshaft sensors but harness and wiring of 2008 come with only 1 socket so i have a disconnected camshaft position sensor and always starting problems
your cooperation is highly appreciated
Old Nov 17, 2024 | 11:12 PM
Happy Hummer's Avatar
I'm in NO way certain if a 2008 can utilize a (06 or 07 engine/harness) without modifications? Clearly you will not be able to operate it with out the extra cam shaft plugged in with reliability. This is a question outside the scope of normal H3 stuff, so i will defer to others who are more knowledgeable.
Welcome and good luck.
Old Nov 17, 2024 | 11:58 PM
AymenB's Avatar
hi sir I'm just using the car its running smoothly just daily it fail to start on the first attempt
the wiring belong to 2008 but the engine is 2006 so I have only 1 socket but there 2 sensors
so while scanning the car always same error coming
Old Nov 18, 2024 | 09:40 AM
First post you said 2007, now you say 2006???? Which is it, 2007s are 3.7L and 2006s are 3.5L?
Old Nov 19, 2024 | 01:34 AM
AymenB's Avatar
so sorry doc it was written by mistake it is 2006
Bonairesurf
Feb 7, 2025 03:21 PM
Bonairesurf
Jan 29, 2022 09:53 PM
Clydesdale
Jun 21, 2021 11:02 AM
Franky
Feb 28, 2020 11:41 AM
t.j.
Mar 18, 2007 12:24 PM
