Code P0455?
Old 12-03-2018, 02:56 PM
Donald Austin's Avatar
Default Code P0455?
EVAP leak? cant seem to find it, even after new gas cap. anyone have this code come up? i have about 195,000.00 miles
Old 12-03-2018, 03:22 PM
Happy Hummer's Avatar
Under a minute to search Google and look.... All kinds of information out there. Searching is your friend.
https://www.google.com/search?q=humm...obile&ie=UTF-8
Old 12-04-2018, 12:01 PM
i should have been more specific, i'm trying to find a diagram of the fuel evap system for a hummer 3 2006 so i can start by trracing the tubes and connections....
Old 12-04-2018, 06:51 PM
Chimpy's Avatar
Most likely the Vapor Canister Vent Valve; pretty common failure on these and the Colorado/Canyons. Dorman part # 911-070. I replaced mine after trying a new fuel cap. It only took me about an hour to do the job. No more EVAP code. You're welcome and good luck.
Old 12-18-2018, 08:58 AM
thnks chimpy
Old 12-18-2018, 09:14 AM
Old 12-29-2018, 03:25 PM
Originally Posted by TAINTER
this diagram is a great help, i couldnt find it on my online manual. is it possible to test the purge valve first before replacing it or replace the vent selenoid first?
Old 01-07-2019, 08:07 PM
norinco3264's Avatar
I just replaced the vent canister on my 06 H3, 99K miles. P0442 code is now gone. Get some PB blaster for the one bolt. I even sprayed the rusty metal clip that holds the canister. As for the hose; I could NOT pull it off. I ended up using channel locks to smash the old canister's hose fitting, then the hose slipped right off.
Edit= this is the one I bought
https://www.amazon.com/gp/aw/d/B001KSCSQU?psc=1&ref=yo_pop_mb_pd_title
Cohiba54
05-31-2018 03:50 PM
Mkawas
01-20-2017 12:02 PM
tharber
02-10-2016 03:06 AM
f1ipX
08-16-2014 03:15 PM
pmedic242000
07-01-2014 07:17 PM
Quick Reply: Code P0455?
