P0455 question?
Old Aug 5, 2014 | 08:24 PM
f1ipX's Avatar
Default P0455 question?
gents i have P0455 code,
loose fuel cap on DIC so tightened it and reset the code gone after a day and back
bought an after market fuel cap did a re-set boom code gone then i thought thats it!
and now its back again P0455, only one code
my question is to those who had this trouble code before, any idea whats next to check?
anyways i watched some u tube vids but cant find anything close to our H3
Thanks J
Old Aug 14, 2014 | 03:37 PM
micjohnso's Avatar
I had same issue turned out the vent solenoid went bad.
Old Aug 14, 2014 | 08:58 PM
f1ipX's Avatar
thanks MicJ, how hard to get this replace buy the part and can i do it myself?i checked underneath seems like only 1 bolt is holding the whole assembly
thanks again j
Old Aug 15, 2014 | 08:43 AM
citiboy's Avatar
Hey J, i have the same code on my wife H3 and replaced the vapor canister vent shut valve with this one
Amazon.com: ACDelco 214-2149 Professional Vapor Canister Purge Solenoid: Automotive Amazon.com: ACDelco 214-2149 Professional Vapor Canister Purge Solenoid: Automotive
Now, you have to remove and re-use the plastic tube and install it to the new valve. Soak it on warm water for easy removal.
Let me know if you need more info as you helped me out before with the roof rack key.
Old Aug 15, 2014 | 02:03 PM
micjohnso's Avatar
Ya really easy to do yourself I took mine to dealer and just had them do it because I was just really busy and needed to pass emissions cost $390
Old Aug 15, 2014 | 11:42 PM
f1ipX's Avatar
Originally Posted by citiboy
Hey J, i have the same code on my wife H3 and replaced the vapor canister vent shut valve with this one Amazon.com: ACDelco 214-2149 Professional Vapor Canister Purge Solenoid: Automotive. thanks for the link brother JM.ordering soon thats so cheap. i haven't call stealership yet so i could get it @ cost
Now, you have to remove and re-use the plastic tube and install it to the new valve. Soak it on warm water for easy removal. ill try with hair blower 1st if that doesnt work.ill use warm water as you said.
Let me know if you need more info as you helped me out before with the roofrack key.
]I'll pm yah if i get lost removing it LOL,yah i see you sent one to another member "roof key
thks J
Old Aug 15, 2014 | 11:47 PM
f1ipX's Avatar
thanks MicJ, my emissions is due nextyear, but i rather fix it now
tks J
Old Aug 16, 2014 | 03:15 PM
citiboy's Avatar
This is what the dealer sells if you ask them, comes complete with the hose. No.1 on the pic. The part that i gave you is the cheapest way to fix that code.
http://parts.nalleygmc.com/showAssem...ssembly=436968
mgurgone
Sep 3, 2014 02:02 PM
Alex2012
Oct 16, 2012 03:39 PM
