'06 H3 with P0442 code
Old Mar 9, 2017 | 10:06 PM
Cohiba54's Avatar
Default '06 H3 with P0442 code
Engine light came on so I had O'Reillys check for code but all they told me was that it's something in the evap system. Want to take care of this but need as much detailed info as possible so I don't start taking things apart that don't need to.
Fire away boyz!
Old Mar 10, 2017 | 06:30 AM
cucumber1949's Avatar
Small leak in the evap system. Start with the low-hanging fruit, which would be your gas cap either not put back on properly or the seal on the cap. Next would be the evap system hoses.
Old Mar 10, 2017 | 07:13 AM
Cohiba54's Avatar
Ok. I've checked the gas cap seal, tested it by smearing grease all the way around the rubber and had full contact on the filler neck. Where is the system hose?
Old Mar 10, 2017 | 08:55 AM
Try a search, this is basic stuff. Been beat in the ground like a rail road spike.
https://www.hummerforums.com/forum/h...42-code-33936/
Old Mar 10, 2017 | 04:33 PM
Did you just fill up your rig before the code popped up?
After reseating the fuel filler cap did you clear the code manually?
The code will not clear right away. You may have fixed it and don't know yet.
Old Mar 11, 2017 | 04:57 PM
dontheo55's Avatar
I believe it has to go through the purge before it will clear if you have fixed it. A search would be a good idea because I read for about 2 hours on it and was just lucky mine was the has ca.
Old Mar 11, 2017 | 08:57 PM
WR3NCHE4D's Avatar
Everyone has great advice on the topic. Next on the list is the evap vent valve. As the vehicle ages the little plunger stops sealing properly. Unfortunately it is a remove and replace. A proper check requires a scan tool and a smoke machine. If there is a different way to check the vent valve someone post it.
Old May 31, 2018 | 10:52 AM
Kimberly Kraft's Avatar
Default P0442
Fire away boyz!
just take it and have smoke test done it will pinpoint right away. I just did the evap purge vale and canister a bunch of other leaks. 2 months ago now same code which they tell me now vent valve on gas tank. Which of course replace the tank and seal $1252. Extended warranty excludes this but not the other evap system work was all covered $3k. Good luck
Old May 31, 2018 | 03:50 PM
Happy Hummer's Avatar
Lol! We're really friethening ya hay!!!
It's real simple to do this stuff....
Brand new gas cap - ACDelco GT306 GM Original Equipment Fuel Tank Cap $24 at Amazon
Brand new evap vent solenoid - ACDelco 214-2149 Professional Vapor Canister Vent Solenoid $19
A piece of evap hose and two stainless steel clamps.
Done.
Have done this a few times on both H3.
On the slight chance it is a hose leaking you'll be one step closer to figuring it out.
hummermongolia
Oct 4, 2015 07:55 PM
mikabika
Oct 9, 2014 04:12 PM
pmedic242000
Jul 1, 2014 07:17 PM
Khrome
Jun 27, 2014 06:54 PM
Alex2012
Oct 1, 2012 01:53 PM
