Basic single din radio upgrade question
Old Oct 29, 2025 | 03:06 PM
gaber6's Avatar
Originally Posted by ski.dive
I got the METRA GMOS-04 WIRING HARNESS ,
for a double din stereo with a Backup camera that I purchased 4 years ago on Amazon for $89-It works great
Ok but did you have to add ANY wires from the radio to the battery or fuse box or did it just plug and play..
This is my question about the adapters.
Old Oct 30, 2025 | 01:50 PM
they should be plug and play
no mods needed.
Old Oct 30, 2025 | 02:10 PM
Your FIRST step is to know what OEM Stereo you had/have. Monsoon has the sub in the rear left side interior panel.
Two - what Radio you are going to use for replacement.
Third - the required Adapter to wire it and or what specific Adapter you are trying to use.
For anybody to assist you they NEED to know one through three above, just like you should. The old "I got a replacement radio and it don't work.... what should I do?" That is an invitation for wild guesses and I do not bother.
Good luck.
Old Oct 30, 2025 | 03:18 PM
gaber6's Avatar
no mods needed.
Ok that makes the most sense as I expect that is how the adapters should work.
Like why even have the red and yellow wires in the adapter plug if I can't use them.
I thought the fact that the adapter was specific to my car on the one i purchaseed would mean it would work, but I didn't know initially that there are additional modules.
Old Oct 30, 2025 | 04:55 PM
ski.dive's Avatar
Use the METRA GMOS-04 WIRING HARNESS----- PLUG AND PLAY
Old Oct 30, 2025 | 05:12 PM
gaber6's Avatar
Yep. Thanks so much!
Old Dec 12, 2025 | 06:51 PM
gaber6's Avatar
Got the gmos-04.. sheesh $100 on ebay but it works perfect plug n play. I like having the chimes as i am in and out of doors a lot and have things often in the way
NGC
Mar 29, 2023 09:56 AM
chevykev
May 6, 2021 01:06 PM
Loria_03
Feb 25, 2019 02:46 PM
jbs45
May 17, 2011 10:55 AM
triplej2k6
Nov 30, 2007 10:35 AM
