Anti theft problem
Old Nov 14, 2025 | 09:38 AM
  #41
NFS's Avatar
NFS
are you sure you have the right cam for your head? diffrent years have diffrent sensor positions. some have one sensors some have 2.
you talking about the cam sensor or the crank sensor?
yes my cams were the same I didn’t change those with the rebuild. I have 2 cam sensors , one is exhaust and one is intake . But that’s not the problem. The problem. Is my crankshaft sensor pushing low voltage 0.11 is not enough for the pcm to command . I had someone suggest to maybe tap on it and see if it like sit more in. I’ll try that today
Old Nov 14, 2025 | 02:30 PM
  #42
yeah both mating surfaces need to be clean and flat, engine block and sensor.
for some reason i understood you mentioned cam sensors.
Old Nov 14, 2025 | 02:43 PM
  #43
NFS's Avatar
NFS
Default Update!
Great news guys! So that Amazon sensor that someone on here told me about worked!!!! I had the crank disconnected but I had the fuel pump jumped to test for fuel pressure. I cranked it I got 0.3 and the truck started! It was freaky becuase the engine ran without no battery or crankshaft sensor lol because I had that jumper cable. As soon as I took it off it stopped! But the great news is that it actually started!!! I am gonna install the new connector ! And make sure it’s good and do a real test after . I’ll keep yall
updated
also if anyone looking for oem crank shaft sensor I found an oem On Amazon
https://a.co/d/0xinGVb
Old Nov 14, 2025 | 04:14 PM
  #44
Happy Hummer's Avatar
Well, that is great news. Thank you for follow up.
Old Nov 15, 2025 | 07:05 AM
  #45
NFS's Avatar
NFS
thank you! This weekend I am going to rewire that new crankshaft connector and I’ll plug it in and fire it up.
ill post another update once that done
Manassahummer
Jul 28, 2023 10:39 AM
oceanbrave
May 26, 2017 04:22 PM
jchummer
Dec 28, 2012 06:08 PM
tuffenuff
Jul 13, 2012 06:03 PM
BobsHummer
Apr 11, 2011 06:32 PM
