AC Blower fix
Old Jul 20, 2011 | 09:11 AM
  #71
Khrome's Avatar
If you order the red connector that attaches to the resistor (GM Part #12059296), it is just a plastic case you need 5 Terminal Pins GM 12015860. Your dealer should have them in stock (msrp $1.02)
You also should use a proper crimping tool.
Old Jul 20, 2011 | 09:17 AM
  #72
Broken Halo's Avatar
Originally Posted by Khrome
Near the beginning of this thread I saw the fix for the resistor was to remove the red plug and solder the wire directly to the terminals in the resistor, but not replacing the resistor. I have a concern if there is a problem with the resistor there will still be heat buildup and the wire will just burn up in a different place maybe up the wire harness in a weaker place. I installed a new resistor and a new red plug. I was thinking if the resistor went bad I would rather it burn up the red connection than burn up a spot further up the harness.
The gauge of wire used, and the terminals themselves, are sufficient to handle the amperage passing through them to operate the blower. The reason for the heat build-up and consequent melting of the red housing is the 'arcing' from the spade terminals not making ideal contact with each other. If you solder to the terminals, you won't have the 'arcing' travel up the wires.
As far as the resistors having a 'problem', resistors are either good (generating heat by resisting the flow of current), or bad (open circuit, not allowing current to pass through, and no heat produced).
Old Jul 20, 2011 | 09:46 AM
  #73
Khrome's Avatar
Ok thanks for the info. From what I see in the pictures everyone is having that same blade arcing and burning. That must be the one with the most current. So the major flaw is the crappy connector and I just put another one back on.
If the resistor is faulty does it just cause a loss of one or more of the fan speeds?
Old Jul 20, 2011 | 09:51 AM
  #74
Direct current (not passing through the resistor) will operate the blower at maximum capacity. When the current passes through the resistor, it's reduced, and gives you the different speeds. Think of it as a dimmer on a light switch....that's a resistor.
Old Jul 22, 2011 | 04:11 PM
  #75
Chief Alex's Avatar
Thanks for the info. I fixed my blower in about 2 hours
Old Jul 22, 2011 | 04:16 PM
  #76
Chief Alex's Avatar
Thanks for the info fixed mine in about 2 hours
Old Jul 22, 2011 | 04:29 PM
  #77
Chief Alex's Avatar
Originally Posted by cdobis
I'm proud of you for having the gonads to fix it yourself!
Mine has been working great for a month now and I have tried all speeds for extended times now. I think it is fixed for good, this time.
Let's hear from others doing this fix, ok?
Thanks for the info mine is fixed
Old Jul 23, 2011 | 10:30 AM
  #78
theindian's Avatar
Originally Posted by b622r
Great info...I took a little different approach. I cleaned the contact. I soldered a wire onto the one terminal only. I drilled out the melted plastic male connector and removed the wire. Then I plugged it back together with the wire running through the enlarged whole and connected it to the source wire.
Mine stopped working last night tried your approach and worked out great thanks a mill.
Old Aug 12, 2011 | 08:05 PM
  #79
Gupone's Avatar
Mine is a 06 with over 60K miles. The blower just went out and the harness was burn't as described by all others. I did the fix but was wondering if the resistor is suppose to be really hot.
After doing the fix I turned on the A/C before putting the resistor back in the housing and the risistor was damn hot and smelled like it was burning. Normal? if so, when you put it in the housing, does the fan blower blow on the resistor to keep it cooler?
Thanks in advance.
Old Aug 12, 2011 | 09:59 PM
  #80
drtom's Avatar
Banned
yes, it will burn up if not in the air flow
