ABS Fault, Traction Control Failure, Service Stab Sys.
Old Aug 9, 2021 | 11:24 AM
  #41
NFS's Avatar
NFS
Originally Posted by billygsims
this is the one I got off Amazon
Oh okay I found oem ones on eBay for 20 bucks that are new so I ordered one night as well replace it it’s cheap
  #42
Oh Boy!
One thing to completion at a time.
Spraying parts and efforts all over the entire project usually fubars the gerdoo out of figuring out what the problem actually is. Why, because you create more issues as you are searching for the original problem to solve and cannot return to the status of the original problem to reach a diagnosis.
Then throw a Yaw sensor at it, NOT!
Good luck.
Old Aug 9, 2021 | 11:27 AM
  #43
NFS's Avatar
NFS
Oh Boy!
Good luck.
what do you recommend then? I tried everything from cleaning ports and all. I replaced the rear left sensor and that fixed one of the problems. The other problem left is switching to 4lock hi and 4 lock low
Old Aug 9, 2021 | 04:13 PM
  #44
Yaw sensor is NOT GOING TO FIX YOUR ISSUE!
Simple explanation just for you. When you turn a light switch on in your home, it sends signal from the panel to the light. However in your case there is a module in between calculating feedback between the light switch and the light.
BTW, DO YOU KNOW HOW TO CHECK 4WD <<<LOCK>>>? That would be helpful to narrow it down.
Switch connector/corrosion, Encoder wiring/connector corrosion/locked up, TCCM, connector/corrosion.
Old Aug 9, 2021 | 05:18 PM
  #45
NFS's Avatar
NFS
okay great! Please tell me how to check 4wd lock? And how to check that module? Where is it located?
thank you for trying to help me
Old Aug 9, 2021 | 06:06 PM
  #46
Can't help you there, I never needed the lockers. Many posts showing lockers cause binding while turning.
Old Aug 9, 2021 | 06:54 PM
  #47
billygsims's Avatar
Default I disagree
I had the EXACT SAME ISSUE with the stab system warning, abs warning and the trac control warning. The yaw sensor fixed every single one of them. I never said it would fix not going into the 4x4 selectors. But it DID fix my issues with the lights AND was the top repair in shop key direct hit. Sooooooo I stand by my assessment.
Old Aug 9, 2021 | 06:57 PM
  #48
billygsims's Avatar
Default He meant neutral.
Gibberish! What language do you speak?
I remember why I stay off forums now. The guy was asking a question. No need to be rude because you know more man. No. Neutral takes it completely out of any gearing 4, 4 hi or 4 low. Your issue is either the switch assembly or the encoder motor.
Old Aug 9, 2021 | 07:03 PM
  #49
NFS's Avatar
NFS
Thank you, can you please tell me where is the switch assembly are the switches right? I think they are working fine if they are the 4x4 buttons . So maybe leaning more toward the encoder. Do u think it might be the TCCM?
Old Aug 9, 2021 | 07:12 PM
  #50
NFS's Avatar
NFS
also how can I test the encoder to make sure it’s working properly? I know when I look at it under the car it’s so rusty and old
