ABS Fault, Traction Control Failure, Service Stab Sys.
Old Aug 11, 2021 | 06:58 PM
  #61
billygsims's Avatar
If you hear it moving under the truck it’s most likely partially engaging most likely from a bad encoder motor. It should be the shifting mechanism itself but I highly doubt it. More apt to be a weak or broken encoder.
Old Aug 11, 2021 | 06:59 PM
  #62
billygsims's Avatar
Could be….not should be.
  #63
billygsims's Avatar
I say this because it is giving you the fault code. I doubt the buttons malfunctioning would cause this.
Old Aug 11, 2021 | 07:08 PM
  #64
The transfer case selected range has been reported as invalid by the transfer case control module (TCCM).
Old Aug 11, 2021 | 07:22 PM
  #65
billygsims's Avatar
do you think it’s due to improper synchronization inside the transfer case ? That’s my guess. Maybe the motor is too weak to fully engage the collar into the gear ?
Old Aug 11, 2021 | 07:32 PM
  #66
Originally Posted by billygsims
I remember why I stay off forums now. The guy was asking a question. No need to be rude because you know more man. No. Neutral takes it completely out of any gearing 4, 4 hi or 4 low. Your issue is either the switch assembly or the encoder motor.
Did you check out my other 5k+ posts? Do you also know that you can save a lot$$$$$$ when you get the right information? Instead of people guessing and causing you to throw parts at it!
If you can't handle my question, you need to go to a forum for arts & crafts.
My response to get more clear information on this post:
Originally Posted by NFS
I did the natural thing. And the car did exactly what in the video if I choose back the 4 down it goes to it no problem but if I choose 4 down lock or 4 up lock. It give me the same mat. What’s the natural thing anyway? Can you drive on the nutural if u want to?
Old Aug 11, 2021 | 08:24 PM
  #67
billygsims's Avatar
my information is quite good my friend. I’ve owned an H3 for 10 years and there isn’t much that hasn’t F’d up on it that I haven’t fixed. Psssst I’m also the son of a 40 year mechanic and have access to all of his wonderful and quite expensive toys that he keeps very up to date. So my advice wasn’t a “guess” it was informed through not only trial and error but very intensive research on the exact issue he is having. And I still stand by my original assessment. There’s no point in being a dick to someone when they clearly don’t speak English as a first language. Never hurts to be nice to people. Have a good un now. Ya hear.
Old Aug 11, 2021 | 09:06 PM
  #68
I'm offering FREE advice here! If you can't handle my questions, look for a forum filled with pansies.
Old Aug 12, 2021 | 08:30 AM
  #69
billygsims's Avatar
Your “free” advice is **** dude. Get some decent equipment to do diagnostics with before you give your free advice out.
Old Aug 12, 2021 | 09:37 AM
  #70
NFS's Avatar
NFS
Great, now you know the TCCM is working properly as previously posted. Now, take the switch apart and clean, also make sure the buttons "pop out" when the next selector switch is pushed. The TCCM is waiting for you to correct the issue.
I will do that on the weekend, it just 3 bolts to take it off I will take it off and clean it and hope that fix it if not I will test it to make sure it’s working and update . Thank you
