ABS Fault, Traction Control Failure, Service Stab Sys.
oh yes I seen this okay sounds good I’ll clean them up and replace that rear left sensor since I already ordered it and clean the TCCM abs cycle again. I will update . I am getting the sensor tomorrow then I’ll do all that at once .
so I guess I need to replace that then
ya I was driving and the like went away. Now when I started the car it came back. I tried to do the cleaning like you told me and it still there. I drove to the gym and still there.
Hey guys here are the updates. I got the sensor and replaced the rear left sensor. Of course it broke but I managed to get it out and put a new one in. Cleared the code and the code and the code away and didn’t come back.
now as soon as I press on any of the 4locks to switch between them I get service 4wheeldrive , service traction and abs. The abs light is on on the dash like when I had the other code l but the traction light is on. Scanned for codes I got the C0276 again
if I turn off the car and turn it back on
the lights abs everything goes back to normal but when I press on the 4locks again I get the code again and it won’t let me press on any of them
what you recommend the next step should be? I cleaned the plugs like you guys told me that didn’t help should I replace the TCCM?
you might have to look at the sensor output on an oscilloscope as it turns because the reluctor wheel might be damaged and not sending the proper pulses. it they are normal then you might have bad wiring.
There's a tsb for transfer case selector switch contamination. Play with the switch, make sure all previous buttons pushed are not stuck in. Try a neutral shift:
https://youtu.be/uqxJAQV-Dn4
but it was shifting before no problem before the whole rear sensor went bad and such. How can I check the sensor output. Can you guid me through it ?
