ABS Fault, Traction Control Failure, Service Stab Sys.
Old Aug 2, 2021 | 04:09 PM
NFS's Avatar
NFS
Default ABS Fault, Traction Control Failure, Service Stab Sys.
I have a 2007 hummer h3
all the sudden got abs fault traction control failure abs such on the dash. I checked the plug on the transfer case it’s plugged in really good, checked the pcm and the wires going to it and they are plugged good . checked the wires on the passenger side those 3 wires plugged in to the module abs they are all good. When I try to switch between the 4 low and high abs such it won’t switch it will keep flashing but will never switch. Any suggestions on how to fix that?
thank you
Old Aug 2, 2021 | 04:23 PM
Read the codes and post them. Can't assist with out the codes.
Old Aug 2, 2021 | 05:38 PM
NFS's Avatar
NFS
I scanned for codes there are no codes
Old Aug 2, 2021 | 05:59 PM
NFS's Avatar
NFS
Ohhh where can I take her to scan her?
Old Aug 2, 2021 | 06:00 PM
Get a scanner with
ABS ABS
capability!
Old Aug 2, 2021 | 06:46 PM
NFS's Avatar
NFS
Get a scanner with ABS capability!
Any place have that?
Old Aug 2, 2021 | 07:03 PM
DID YOU CLICK ON THE BLUE ABS?
You can also get it here: INNOVA 3020RS
Old Aug 2, 2021 | 08:06 PM
NFS's Avatar
NFS
oh I didn’t know lol I just bought it. It will arrive tomorrow
Old Aug 3, 2021 | 05:45 PM
NFS's Avatar
NFS
I got one code is C0045
Old Aug 3, 2021 | 07:39 PM
Left Rear Wheel Speed Sensor Circuit.
ABS/TRACTION light came on, I traced it to the drivers side rear abs sensor.
Removed the bolt that holds the sensor into the rear axle and while removing the sensor, it broke,
flush with the axle housing. I had to chip away at it, scrape off a rust ridge that was preventing it from sliding out.
Then inserted a screw into it and popped it out.
Total time:1.5hr, total cost: $53.99 with tax and next day shipping.
Abs & Traction control operating again. '07 with 90,198 miles.
