2006 hummer h3 leaking oil horribly
Old Jul 15, 2021 | 03:02 AM
Pjxmotorsports's Avatar
Default 2006 hummer h3 leaking oil horribly
My 06 h3 is leaking horribly on the passenger side I can’t tell where it’s coming from but it coats my entire front subframe front diff and everything it’s leaking about 4qts a week or so any help is appreciated will try to attach photos if I can
Old Jul 15, 2021 | 08:37 AM
Oil Leak detection 101.
1) Open hood.
2) Clean the leaking oil mess with degreaser and a power washer top to bottom, fill the oil to proper level.
3) If needed, put the vehicle on ramps up front then do #1 from the bottom.
4) Start engine, get under with bright flash/work light and LOOK where it is coming from.
Old Jul 15, 2021 | 10:27 AM
is it a I5 engine? could be the vvt solenoid.
Old Jul 15, 2021 | 12:50 PM
Dylan Rogers's Avatar
I think Bronxteck's idea of the solenoid makes sense.
Did the leak happen to start after getting an oil change? If so, check the oil filter for leaking oil (or make sure it has an oil filter on!). 4 qt.'s per week is a ton of oil loss. I imagine it must be something large.
Also, where is the highest part of the engine bay you can see leaking oil on (before washing it)?
Justinh
Jan 7, 2022 12:48 PM
ckhummer
Feb 4, 2018 02:37 PM
H2Miami
19
Mar 14, 2017 08:10 AM
Kkneat
Feb 7, 2016 03:31 PM
Draketh
Oct 23, 2010 05:59 PM
