2006-2010 hummer h3 dash mount headlight fog lamp dimmer control switch oem
Old May 8, 2023 | 10:02 PM
26sonic's Avatar
Default 2006-2010 hummer h3 dash mount headlight fog lamp dimmer control switch oem
2006-2010 HUMMER H3 DASH MOUNT HEADLIGHT FOG LAMP DIMMER CONTROL SWITCH OEM this has been discontinued gm pn# 15101467 any aftermarket or new replacements out there?
Old May 9, 2023 | 07:30 AM
Swap with the coly switch 15187089 Headlight Switch
Old May 9, 2023 | 09:19 AM
26sonic's Avatar
the bottom button on that switch all the way to the right that has no markings on it what is that for? my factory switch on that button has markings on it indicating "on star" ?
Old May 9, 2023 | 12:19 PM
Golden Hurricane's Avatar
My 07 H3X has the On Star button on the factory rear view mirror.
Old May 9, 2023 | 02:12 PM
26sonic's Avatar
my h3 is a 2006 and its on the head light dimmer switch.
Old May 9, 2023 | 03:02 PM
The buttons are removable, swap them.
Old May 9, 2023 | 10:21 PM
26sonic's Avatar
so are you saying the un marked button were talking about is wired for the "on star" and this switch is plug and play?
Old May 10, 2023 | 07:10 AM
The coly used that switch for bed light or on star(pics below). Yes plug and play same 14pin connector.
Old May 10, 2023 | 09:39 AM
26sonic's Avatar
thanks so much for the info !!! i'll order 1 up and give it a try.
Old May 10, 2023 | 01:30 PM
It'll work as long as the switch you get and your wiring are good. Post an update when you install. Btw, the reason the OEM & AM(WELLS WVE 1S8783 ) H3 switches are no longer available is due to the coly and cany owners think the "Hummer switch looks a lot better":
Convert to Hummer H3 headlight switch???
flashinq
Apr 4, 2022 08:23 AM
dbetler
May 14, 2020 11:03 AM
jman1335
Jan 24, 2018 05:34 AM
TeeStu
Jun 4, 2016 03:08 PM
rayfry08
Dec 29, 2014 09:21 AM
