Headlight running lamp and fog light question
Old Nov 20, 2015 | 12:07 PM
dbetler's Avatar
Default Headlight running lamp and fog light question
My question is on my 2006 H2, there are 2 circular fog lights that I cannot seem to locate an on switch for. They go on when the doors are locked or unlocked by the FOB but they do not turn on otherwise. I see no switch to turn them on. Any suggestions on where I might locate the switch to turn on would be appreciated. Thank you.
Old Nov 20, 2015 | 01:14 PM
Baldfox's Avatar
Hey. I think these are the drl's and they come on from the fob as you suggested but they turn off when the headlights are on. I think they're supposed to be driving lights and run during the day when not in park. Have you caught a glimpse of the truck moving with them on? The sensor that turns the headlight on turns them off. The only other option could be a switch underneath the headlight panel on the left of the wheel. I have a small switch under there where the previous owner wired the DRLs separately.
Old Nov 20, 2015 | 05:58 PM
Dieseldrums's Avatar
There is a mod you can search and find that involves running a jumper wire from your headlight to drl relays in the fuse block under the hood so they come on together.
Old Nov 20, 2015 | 11:10 PM
LoJac963's Avatar
As mentioned those are your daytime driving lights. They are on during the day when in drive and off when the headlights are on.
I would definitely do the diode mod mentioned above. This keeps the DRL's on all the time even with the headlights. Double check and triple check when installing the diode to make sure it is oriented in the right direction.
Old Nov 21, 2015 | 11:00 AM
dbetler's Avatar
Default Thank you
Thank you. Good info.
Old May 14, 2020 | 11:03 AM
RKSmith163's Avatar
Welcome. I too have a Black 2010 Alpha/Offroad. I loved my 06 and 08 Luxury Pkgs. also. Wish I had all three.
AR15wheeler
16
Feb 16, 2016 10:42 AM
MH3
Nov 25, 2014 08:01 PM
JJJ
May 19, 2014 07:50 AM
Tag37
Oct 3, 2012 03:53 PM
Chubosco
May 13, 2011 08:56 PM
