06 h3 p0106 and p0301
Old Jul 12, 2022 | 02:56 PM
  #21
Originally Posted by Hummer6895
Yeah tried cleaning it with MAF cleaner just to see, didn't do anything so I changed the MAP all together and am still getting random p0106 p0300 p0301 I clear it restart and it's up in the air which one comes up none of the wires or connectors seem to have a issue so I'm getting the battery charged since it's been sitting for a year to see if it makes any difference
You can clean and throw parts at it, yet nothing worked. BOTTOM LINE CHECK WIRING TO THE MAP!
Btw, what cleaner did you use?
Old Jul 12, 2022 | 03:21 PM
  #22
Including............. the Crappy Azzed OEM Battery Terminal Connectors. The first mod to do to every H3/H3T, and same vintage Colorado and Canyon. Swap out the OEM junk and replace with a quality set like Stingers or your favorite brand.
Cliff prefers battery replacement (note @5:40 the negative terminal already loose when trying to remove the nut)
Old Jul 26, 2022 | 07:50 PM
  #23
Hummer6895's Avatar
https://youtu.be/tiEIZZXvtws
finally was able to ship it local and back probe the map, broken wire, so hopefully that solves it
Dr Whoopie
Jun 19, 2020 05:21 PM
Patrick D
16
May 2, 2019 04:09 PM
H2STU
Oct 28, 2015 05:36 AM
norinco3264
20
Apr 25, 2014 05:51 PM
Happy Hummer
Dec 15, 2012 02:45 PM
