06 h3 p0106 and p0301
Old Jul 11, 2022 | 08:50 PM
Hummer6895's Avatar
Default 06 h3 p0106 and p0301
Hi, I have the two codes p0106 and p0301. I've r&r'd the intake manifold and gaskets, swapped coil packs, spark plugs, injectors, just changed the timing chain out prior to these codes after the truck has been sitting for a year and a half. Any advice or experience seeing these two with all those items checked?
Old Jul 11, 2022 | 09:39 PM
Did you reconnect the map sensor?
Old Jul 11, 2022 | 09:44 PM
Hummer6895's Avatar
Yes cleaned reinstalled map, cleaned intake and ports while I was at it too no change.
Old Jul 11, 2022 | 10:06 PM
Check the wires to the map connector, failures reported occur within inches of the connector.
Old Jul 11, 2022 | 10:18 PM
Hummer6895's Avatar
Whats the best way to check with no multimeter and poor electronic skills or is a multimeter required
Old Jul 12, 2022 | 10:07 AM
Hummer6895's Avatar
Two out of three are not showing continuity so hunting for the breaks
Old Jul 12, 2022 | 10:17 AM
Eyeballs.
Old Jul 12, 2022 | 10:54 AM
Hummer6895's Avatar
Disregard wires check out going to swap the map
Old Jul 12, 2022 | 11:21 AM
Hummer6895's Avatar
Swapped map now p0300 only
Old Jul 12, 2022 | 11:36 AM
Hummer6895's Avatar
Jesus disregard again now p0106 is back with p0300
