Starting hummer = roo roo roo sound
Old Oct 4, 2019 | 08:52 PM
hummer_on_fumes's Avatar
Default Starting hummer = roo roo roo sound
For awhile now when I start the hummer it is really sluggish to crank and makes a roooo roooo sound like the battery is dying. It is a new battery within the last 2 years. Has anyone had this symptom before? It has never not started, it just acts like I'm starting from a battery that's almost dead. I presume eventually it's going to not start, because it's been gradually getting worse over the months.
Old Oct 4, 2019 | 09:32 PM
i guess check the normal stuff like battery terminals, ground straps, but it could also be the starter is showing its age. check the starter terminals for corrosion.
Old Oct 4, 2019 | 09:45 PM
Perform a CA Test.
Btw,
One question: Are you still using the crappy azzed OEM Battery Terminal Connectors?
If so, do yourself a favor and hack them off and replace with a quality aftermarket set like Stingers or your favorite brand. .
Old Oct 4, 2019 | 10:45 PM
Ricardowelch's Avatar
Originally Posted by hummer_on_fumes
For awhile now when I start the hummer it is really sluggish to crank and makes a roooo roooo sound like the battery is dying. It is a new battery within the last 2 years. Has anyone had this symptom before? Visiting Autofthings to review top rated battery tender if you concern. It has never not started, it just acts like I'm starting from a battery that's almost dead. I presume eventually it's going to not start, because it's been gradually getting worse over the months.
I think you should check if there is a combination of electrical problems as damaged relay, fuse and the ignition cylinder being broken.
Old Oct 5, 2019 | 08:05 AM
calif phil's Avatar
Charge the battery to 12.6 volts and then have it load tested, that is the first thing to do.
Old Oct 11, 2019 | 11:39 AM
Update: had battery tested and it's bad, ordered a new one. Sucks becuz I've only had it since April 2017 and it was just barely out of warranty
crum55
Aug 17, 2018 06:11 AM
jens
Jan 27, 2015 02:53 PM
y2jonkurtz
Nov 28, 2014 03:00 PM
GuestWho
Feb 6, 2012 07:23 AM
Rickwpip
Aug 29, 2011 04:12 PM
