Ranco lift bushes H2
Old Oct 2, 2025 | 01:06 PM
Eddy Lee's Avatar
Question Ranco lift bushes H2
I have a 2004 H2 with a Ranco lift. The bushes in the front differential are non standard as you have to do some cutting when doing the lift. Two of the bushings are breaking up badly now. Ranco say they do not make them anymore and cannot help. Does anyone know when i might find these bushings so I can stay on the road.
Front bushing
Front bushing
Rear bushing
Rear bushing
Old Oct 2, 2025 | 03:20 PM
RobertDez's Avatar
If you don't have a metal lathe, any machine shop should be able to make you some replacements out of aluminum. I used to make solid leaf spring shackle bushings on the lathe all the time. (The racing crowd prefers solid suspension bushings. Improves the handling. Not to mention they're a lot more durable)
Old Oct 2, 2025 | 05:58 PM
Eddy Lee's Avatar
Great, thanks for the advice. If I cant find them I will try to find someone to do that. Great workaround
Old Oct 3, 2025 | 08:06 AM
calif phil's Avatar
Another idea would be to check with someone like Energy Suspension and see if they have something similar, chances are they might have even made them for Rancho.
Old Oct 3, 2025 | 09:46 AM
Old Oct 3, 2025 | 10:40 AM
RobertDez's Avatar
That's another excellent idea if you don't want the solid bushings.... but I would go ahead and have two sets made, hasn't appears your lift kit really eats them up?
Old Oct 3, 2025 | 01:07 PM
Eddy Lee's Avatar
Thanks everyone, following up on all suggestions. I will let you know the outcome.
Old Oct 3, 2025 | 01:11 PM
Eddy Lee's Avatar
​​​​​​Yes it does. Also eats CV joints, I'm on my second set now!
Gavin Costigan
Dec 9, 2025 09:54 PM
Tony-Nav
Apr 30, 2024 11:06 AM
LifeIsGood
Feb 2, 2024 12:00 PM
WFarm
Hummer H2 SUT
Jan 11, 2024 09:58 AM
Chrmer3
Feb 1, 2020 07:55 PM
