Am I missing a sleeve>? Front diff H2
Old Feb 1, 2020 | 05:03 PM
Chrmer3's Avatar
Default Am I missing a sleeve>? Front diff H2
I am removing the front differential cross support - only way to get the bushing replaced (unless I wanted to go with the other aftermarket bushing solutions) was to order the entire cross member.
Anyways I was going to swap out and I removed this one bolt that runs through the bushing to the diff - there is all sorts of room between the diameter of the bolt and the bushings sleeve... Am I missing a sleeve or is it just supposed to float all around in this bushing???
Seems like surely there should be a sleeve between the bolt & the bushing to make up for the slop>??
Hopefully this gets responded to fairly quickly so I know what direction to go in...
Thanks in advance
Chris
Old Feb 1, 2020 | 06:01 PM
The sleeve is encapsulated in the bushing. Just make sure to properly torque the bolt.
Old Feb 1, 2020 | 06:05 PM
iwillnc's Avatar
That is a lot of room, if I was at home I would pull out my manual and check to see if it’s mentioned, or pull my bolt out because that does seem like a lot.
Obvious question, how did the old one look? Was there that much space?
Old Feb 1, 2020 | 06:10 PM
Old Feb 1, 2020 | 06:19 PM
Chrmer3's Avatar
I dont know much about suspensions etc, but this makes no sense to me... when even bother with a sleeved bushing if the diameter is double the size of the bolt? lol?
Its surrounded by rubber that in all my years of replacing mounts, I have never seen one with this kind of slop by design...
Oh well, I guess I will carry on with install, although my inner self wants to mic the inner of the bushing & outer bold to fabricate a sleeve....
Thoughts from the smart suspension people??
Thanks!
Chris
Old Feb 1, 2020 | 06:25 PM
Chrmer3's Avatar
And yes= this is exactly as the original one is on the truck now, I just had the oil pan gasket replaced and the GM (Yes GM dealership) garage, left 4 of the oil pan bolts loose, one almost falling out (harness stopped it) and one nut on one of the diff bolts... so I was assuming they may have left out this sleeve also since it would have been removed to do the pan gasket...
I had seen this bolt off center when I was under the truck checking for oil leaks and "assumed" my bushing was shot. (so I ordered the new replacement)... Upon disassembly I think I spent $385 for nothing . Learn by doing... I'll put the new one in & sell this crossmember on ebay since its most appears now to be fine.
I really thought the bushing was separating since it was no longer center by viewing..
Old Feb 1, 2020 | 06:35 PM
Thanks!
Chris
That would cause a squeak. Bolt, washer, sleeve, washer, nut..torque properly and the bolt will have limited movement. The bushing takes control.
Old Feb 1, 2020 | 07:03 PM
Chrmer3's Avatar
Ok - will carry on as is. Any idea of torque? I dont have a service manual to refer to, I suppose I can go off general torque for this bolt size
Old Feb 1, 2020 | 07:55 PM
bushing/pocket bolt-70 ft lbs/105 ft lbs
Gdraft
Feb 8, 2024 11:39 AM
h3carlos
Jul 30, 2019 12:05 PM
blazed16
Oct 19, 2018 12:03 AM
surfnaked
May 1, 2013 07:16 PM
204H3T
Mar 17, 2013 02:48 PM
