Body Mounting olt and Bushing Kit for 1.25 Lift
Old Apr 28, 2024 | 06:04 PM
Tony-Nav's Avatar
Default Body Mounting olt and Bushing Kit for 1.25 Lift
Read some of the threads. Found Gas wrench or machine shopbest solutiond for body mounting bushing and sleeve seizing. Aside that, anywhere to purchase these items?
Old Apr 29, 2024 | 07:11 AM
Happy Hummer's Avatar
I've watched this YouTube video a few times. Very economical and pretty straightforward. Jmho
Old Apr 29, 2024 | 10:35 AM
Tony-Nav's Avatar
Thanks for the vid. Problem is they wont come loose at all. I may have to take it to machine shop to get the seized ones pressed out. Maybe a torch and a vice, or just pull and replace.
Old Apr 30, 2024 | 09:47 AM
Try soaking the bolts & sleeves in PB Blaster or CRC Freeze off overnight. Hold sleeve in the vice and use a 3lb sledge on the bolt (use a nut on the end for more surface to hit.
If that does not work, fire wrench in the same sleeve/vice/sledge set up.
Old Apr 30, 2024 | 11:06 AM
Tony-Nav's Avatar
Thanks man… Great advice. I’m soaking it now.
LifeIsGood
Feb 2, 2024 12:00 PM
h3carlos
Jul 30, 2019 12:05 PM
surfnaked
May 1, 2013 07:16 PM
hummer1
Mar 9, 2007 04:26 PM
