H2 with Ranco lift oil pan removal
Old 05-06-2022, 09:48 PM
Eddy Lee's Avatar
Default H2 with Ranco lift oil pan removal
I have a 2004 H2 with Rancho 4" lift. I need to replace the oil pan gasket, I have no problem clearing the front diff because of the lift. But the Rancho sub frame assembly gets in the way by about 1/2 an inch. This is a welded item and does not have a bolt on cross member. Has anyone ever done one of these as I cannot see how it can be done without complete disassembly. Already taken all the bolts out of the oil pan so now stuck in my garage. Help
Old 05-09-2022, 09:30 AM
MOVED, no tech questions in the New Member Section. All H2 questions go in the ........................................ yep........................................ H2 Section.
If the pan can drop, it does not need to be removed to replace the gasket. Of course that is a matter of degree. You still need enough space to remove the old and place the new.
Old 05-09-2022, 10:18 AM
Eddy Lee's Avatar
OK thanks,But I thought the pick up tube would prevent sliding a new gasket in?
Old 05-09-2022, 12:32 PM
If the pan drops about 1/2" plus, you can unbolt the pickup tube from the oil pump, disconnect, then re-bolt it to torque. Just did that when I did a cam swap on my 09 H3 Alpha and needed to replace the chain, removed the oil pump, then put it back with the pan about 3/4" lower than the block. Not too difficult. There are vids on how to replace oil pumps on LS motors with the engine in the truck, oil pan loose.
Good luck.
georgethe3rd
10-30-2021 10:46 AM
chopper1
06-30-2015 05:05 PM
hmer
01-20-2015 07:17 AM
HummerKid82
03-08-2008 10:35 PM
Quick Reply: H2 with Ranco lift oil pan removal
