Blend Door issues? Here are your answers!
Old Dec 2, 2017 | 05:47 AM
  #31
clsimmon's Avatar
Originally Posted by faresmotors
Hi All and thank you for your help.
My AC is working fine. I have a problem with the heating: Driver side is HOT AIR while Passenger side is COLD AIR, which BLEND DOOR ACTUATOR shall I replace?
Regards, YF
It depends on which one is not working correctly. Turn your temp all the way down on both sides and all the way up. Which side; passenger or driver is malfunctioning? That is the blend door to replace. See starter post in this thread to locate and replace the correct one.
Old Dec 2, 2017 | 05:54 AM
  #32
clsimmon's Avatar
How do you call the unit of the ac/heating control (in front of the gearbox)?
I'm assuming you are referring to the Air Conditioning Control GM 15832311 in front of the gear shifter; correct?
Old Dec 3, 2017 | 04:37 AM
  #33
faresmotors's Avatar
Old Dec 4, 2017 | 12:03 AM
  #34
Cool
Hi, ok... I have 2 doors to replace:
1- for the air coming from outside (fresh air)
2- for the hot/cold air passenger side...
I ordered 3 doors as attached... frankly I didn't understood the difference between them
Old Dec 4, 2017 | 10:26 AM
  #35
jd1368's Avatar
question on this one. basically all of my vents are blowing cold air ,but turning the thermostat on and off and adjusting the temp back and forth they eventually all turn warm after a while. i'm not getting any warning lights. does this sound like the actuators, or another issue?
Old May 31, 2018 | 05:43 PM
  #36
dr_funk24's Avatar
i want to revisit this issue/topic and any other posts, comments, or links would be greatly appreciated....
im having a problem that i was thinking could be the door actuator but im not so sure. If i have the key in but just in the "on" position, the air comes out of the correct vents, but once i start the H2, the only thing that works is the defrost vents. all i know is this sounds expensive! haha
Old Jun 1, 2018 | 12:34 AM
  #37
What do you mean by:
you don't receive AIR from other outlets?
Old Jun 1, 2018 | 07:48 AM
  #38
dr_funk24's Avatar
no matter what mode i have it on, the air only comes out the defrost slots, i have had a couple times that the passenger side front vents work, but that is rare. it just baffles me that it works ok usually when in the "on" position, then i start it and it loses its damn mind!
Old Jun 1, 2018 | 11:27 AM
  #39
H2 model? 2008-2009?
Old Jun 1, 2018 | 11:29 AM
  #40
dr_funk24's Avatar
H2, 2004
